Rookie1707822686 Posted December 24, 2021 Share Posted December 24, 2021 Hi all,I have bought a Select DCC controller, I had connected it to the tracks, but I whenever I put the DCC enable locomotive on the track DCC's display goes off and a tik tik sound is coming out, I am not sure that the sound is coming from tracks or from DCC itself, but locomotive is not getting registered, when I take locomotive off the track, display comes back and tik tik sound stops, what could be the reason behind this coz I have already spent alot of money on decoder and DCC, kindly suggest.Thanks.Please help! Link to comment Share on other sites More sharing options...
Chrissaf Posted December 24, 2021 Share Posted December 24, 2021 Almost certain that the locomotive has a 'short circuit' fault. You can confirm this by putting a multimeter across the wheels set to measure resistance.Multimeters can be purchased cheaply off ebay for less than £8 delivered. Link to comment Share on other sites More sharing options...
Rookie1707822686 Posted December 24, 2021 Author Share Posted December 24, 2021 Thanks! But there is a catch, after all effort I decided to remove decoder (8 pin decoder) and run locomotive by a simple Dc current and it ran. What do you say about it. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 24, 2021 Share Posted December 24, 2021 That doesn't change my diagnostic diagnosis. It just points to the decoder being faulty and creating the short circuit between the black and red wires on the decoder. Link to comment Share on other sites More sharing options...
96RAF Posted December 24, 2021 Share Posted December 24, 2021 Reverting the loco to DC by inserting a blanking plate simply connect the wheels on each side to the motor direct. When a decoder is plugged in you use all 8-pins and if there is a short twixt any two the fault will show. That is in addition to the possibility of a duff decoder.Lift the decoder socket and ensure there is no solder tracking between pin traces or incorrect wiring. If you have one try the decoder in a known good loco, rather than risk another decoder in this loco. Link to comment Share on other sites More sharing options...
