Gordon-1234956 Posted December 25, 2021 Share Posted December 25, 2021 Which decoder do I use to enable DCC running of R3953 please ?? Link to comment Share on other sites More sharing options...
96RAF Posted December 25, 2021 Share Posted December 25, 2021 The loco is not DCC-Ready i.e. it does not have a socket to plug a decoder into, so it will be necessary to get the soldering iron out and either hard wire the decoder in or better still install a socket. You can use either a four pin, 6 pin or eight pin decoder.There are guides on the DCC conversions page showing how to hard wire a decoder into several 0-4-0s which are essentially all alike.If you cannot solder then maybe your local model shop offers a decoder installation service. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 25, 2021 Share Posted December 25, 2021 The R3953 is a Hornby Collectors Club 0-4-0 loco, it is therefore the cheapest of the cheap and in my opinion not worth the effort of converting to DCC as the 0-4-0 'wheel layout' locos are notoriously bad runners on DCC. If you do decide to continue with a conversion, then I highly recommend and suggest that you use a non Hornby decoder that comes with a factory fitted 'stay alive' to overcome the potential running issues. It should also be noted that space inside this loco to accommodate a decoder and socket plus a 'stay alive' may not be sufficient.As Rob indicates above, decoders are not loco specific, in principle any decoder can be used in any loco. Choose your decoder brand / model based upon its specification suitability to do the job. In your case as the loco has no lights, you could use a 4 wire decoder as this is likely to mean it is smaller and consider my 'stay alive' comment. Link to comment Share on other sites More sharing options...
ColinB Posted December 25, 2021 Share Posted December 25, 2021 When I converted my 0-4-0 locos, I converted them by using a six pin socket, it is quite easy on these locos. I used the DCC Concepts 6 pin socket as these seem to be the most robust, on a lot of the others the wires pull off too easily. I then used a Zimo MX617 decoder which has a higher current rating than the the Hornby ones and is a nice decoder. The Zimo MX617 also has the option of adding "stay alive" if you want it. Link to comment Share on other sites More sharing options...
