XJR1300 Posted January 15, 2022 Share Posted January 15, 2022 I've been given a R8213 Select Digital Controller, but it doesn't have a power supply. Will the P9000 transformer work? Link to comment Share on other sites More sharing options...
Chrissaf Posted January 15, 2022 Share Posted January 15, 2022 No.The P9000 is for Analogue set controllers. Firstly it is 19 volts not 15 volts, secondly the DC connector is 5.5/2.1mm and not 6.3/3.0mm and the output current is too low.The correct power supply for the Digital Select controller is either the P9100 1 amp power supply or better still the P9300 4 amp power supply. Both these power supplies are 15 volt DC with a 6.3/3.0mm connector for Digital controllers. Link to comment Share on other sites More sharing options...
XJR1300 Posted January 15, 2022 Author Share Posted January 15, 2022 Many Thanks Link to comment Share on other sites More sharing options...
