GrandTour Posted February 14, 2022 Share Posted February 14, 2022 I’ve been using my Hornby Select controller for about a year + now and it is suddenly started displaying a flashing 88 in the LCD screen.Is this some sort of error code or is it something that might be a other function? Link to comment Share on other sites More sharing options...
Jupiter 1707822591 Posted February 15, 2022 Share Posted February 15, 2022 Does it do the same with the track disconnected ?? Link to comment Share on other sites More sharing options...
Chrissaf Posted February 15, 2022 Share Posted February 15, 2022 Can you please confirm what firmware version your Select is using. The very first number to appear briefly on screen as the Select is being powered up. The start up numbers take the form xx 30 03. It is xx that states the firmware. Expect to see a number between 10 and 20. Link to comment Share on other sites More sharing options...
96RAF Posted February 20, 2022 Share Posted February 20, 2022 It has gone into self test mode. To do this you hold the Function button as you power the Select up. I guess the Function button is stuck on. Try exercising it a few times. To get out of self test mode simply power down and up again when you should see the normal series of numbers xx 30 03 as explained by Chris. Link to comment Share on other sites More sharing options...
GrandTour Posted February 21, 2022 Author Share Posted February 21, 2022 Does it do the same with the track disconnected ?? Yes it does Link to comment Share on other sites More sharing options...
GrandTour Posted February 21, 2022 Author Share Posted February 21, 2022 @Chrissaf The flashing 88 has disappeared now and I have the number 10 come up first in the sequence. Link to comment Share on other sites More sharing options...
GrandTour Posted February 21, 2022 Author Share Posted February 21, 2022 @96RAFOn closer inspection the front cover plate is loose and seems to be impeding the function button. I am going secure the plate down. Many thanks. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 21, 2022 Share Posted February 21, 2022 10 ... That is the original version 1.0 firmwareYou are highly advised to have that firmware updated by Hornby to the latest 1.6 version.Version 1.6 totally transforms the Select. Not only does version 1.6 give full support for functions F0 to F28, it also gives support to write to all CVs in the CV1 to CV255 range.The firmware update is a return to Hornby update for which you will need to obtain a "returns number" from Hornby Customer Services. The turnaround is typically less than 10 working days and typically costs £15 plus your sending P&P.After update, the "user interface" [how you use it] is completely different. So you need to download the Select R8213 [version 1.5] manual and version 1.6 / 2.0 Select Addendum manual. Both documents can be downloaded from the "support" section of the Hornby website. Link to comment Share on other sites More sharing options...
96RAF Posted February 21, 2022 Share Posted February 21, 2022 I was going to refer you to my Teardown of the Select so you could better fix it but if its going back for update, leave it as is and let Hornby sort it out for you. Link to comment Share on other sites More sharing options...
