DADnALEX Posted February 18, 2022 Share Posted February 18, 2022 Hello,Is it possible to add TTS sound to the mixed freight set? The DCC decoders already fitted are much smaller and don't plug in in the same way the Hornby TTS decoders do (8 pin).Very much a newbie, so any help appreciated. Picture of the diesel attached.Thanks,Mike Link to comment Share on other sites More sharing options...
Chrissaf Posted February 18, 2022 Share Posted February 18, 2022 Electrically, It is doable but space in the loco will be tight so whether it is physically doable is another matter.The pin connections can be dealt with easy enough, by either converting the 4 pin loco plug to an 8 pin socket or converting the TTS 8 pin plug to a 4 pin socket. I favour converting the loco to 8 pin so that the TTS decoder can be more easily replaced if needed. The pin out information you need can be found on Brian Lamberts Decoder pages. A link to these pages will be found in the "Useful Links" sticky thread at the top of the "General Discussion" forum.The issue I see is the TTS speaker, it is highly likely to be far too large to physically fit. The supplied TTS speaker will likely need replacing for a very much smaller one [look at the YouChoos website for speakers].All of this needs fine soldering skills.As this is your very first post on this forum and my reply is a very long one. Please reply using the "Reply Text Box" at the bottom of the page and ignore the within post blue button which is not a reply to this post button. Thank you for your cooperation. Link to comment Share on other sites More sharing options...
Howbi Posted February 18, 2022 Share Posted February 18, 2022 The existing 4 pin socket needs to be removed and replaced by soldering the 2 track wires and 2 motor wires to the relevant pins on an 8 pin socket. A sugar cube type speaker can be stuck with double sided pad to the back of the loco's radiator. A photo of my solution fitting the TTS to an 08 loco will be posted when approved.........HB Link to comment Share on other sites More sharing options...
Howbi Posted February 18, 2022 Share Posted February 18, 2022 Link to comment Share on other sites More sharing options...
Chrissaf Posted February 18, 2022 Share Posted February 18, 2022 Pre-wired 8 pin sockets to make conversion easier.https://www.ebay.co.uk/sch/i.html?_nkw=prewired+8+pin+dcc+socket&_trksid=p2334524.m4084.l1313&_odkw=8+pin+dcc+socket&_osacat=0Of the eight wires included on the socket, only the red, black, orange and grey wires are used. Link to comment Share on other sites More sharing options...
DADnALEX Posted February 20, 2022 Author Share Posted February 20, 2022 Thank you both very much for your replies.'Fine' soldering skill might be the issue here! My soldering is pretty messy :(Good to see that it fits though. Much easier to have a go knowing that it can fit back together afterwards!Hmm, decisions... Link to comment Share on other sites More sharing options...
Chrissaf Posted February 20, 2022 Share Posted February 20, 2022 Re: fine soldering.It might be useful to read FAQ3 located in the "General Discussion FAQ Index" sticky thread. If changing the speaker use the soldering iron at the speaker end wires, not the decoder end. Link to comment Share on other sites More sharing options...
DADnALEX Posted February 22, 2022 Author Share Posted February 22, 2022 Thanks Chrissaf :)Will do RDS Link to comment Share on other sites More sharing options...
