Hornby Prarie motor
Mist22
I bought, second hand, a Hornby Prarie loco R2098A. It had been converted to DCC. It looks as though the motor now needs to be replaced and the service sheet says this is an X3874. I haven't been able to find one. Does anyone know where I might get one or what I can replace it with please?
It also looks like the standard one fitted into the Tornedo, Duke of Gloucester and Railroad Mallard. The only thing is these have a double shaft as they have a flywheel so you might need to grind the other end off. If you want a five pole replacement the Pendolina one should be the same size again with two shafts.
