StephenE Posted July 24, 2012 Share Posted July 24, 2012 Hi I have a couple of locomotives that have been converted to SoundTraxx Tsunami decoder chips. I need to change the address on the chip form the default 3. At the moment I find myself up against a brick wall, the decoder manual say to use service mode at any time and then it mentions using operations mode and it speaks about CV 29 restrictions whilst using operations mode> Does anyone have any proven ideas on how to go about it. Regards and thanks Stephen Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 24, 2012 Share Posted July 24, 2012 Hi Stephen, just follow the instructions on page 10 of the Elite manual, that's all that's needed. You don't need to worry about anything else for now. Link to comment Share on other sites More sharing options...
Gregd99 Posted July 24, 2012 Share Posted July 24, 2012 service mode is programming on the programme track. operation's mode is programming on the main track. to start off with just use the prog track. Link to comment Share on other sites More sharing options...
StephenE Posted August 20, 2012 Author Share Posted August 20, 2012 I have just reset the decoders id's using of all things my Hornby Select apparently the issue comes back to low voltage on the programming track, I had thought of buying SoundTraxx's PTB-100 programming track booster which amplifies the current and signal on the track also has some error testing capabilities, but then my son did some research on the web and 1 suggestion was to try using the Select controller and it has worked, so thanks to Gregd99 and Fishmanoz. Regards and thanks Stephen Link to comment Share on other sites More sharing options...
