Programming Track
Sri-355216
Hi,
Is it possible to use a isolated section of the power track and a crossing points track from Hornby as a programming track? I have the DCC Select controller and DCC Points Accessory Decoder. Need to program 16 points and don’t want to do it on my running layout.
Just disconnect the layout from the Select and connect a feed from each point decoder in turn to the Select.
Once programmed connect the decoders to your track bus, noting that the Select uses point addresses starting at 61.
Thanks. That helps
