R3284TTS tender
Dr Al
If I recall correctly one screw holds the body shell of Tender. It's underneath the rear coupling so you will need to remove that first with small screwdriver by pushing upwards, after inserting the screwdriver underneath of the rear coupling. Coupling is push fit type. Or you can watch this video on you tube.
