James-783317 Posted July 2, 2022 Share Posted July 2, 2022 I am having a problem with R8107 tts decoder.The sound keeps cutting out, engine still runs though.To rectify, the power needs turning off, then its runs fine with sound ok.Help.Jim. Link to comment Share on other sites More sharing options...
96RAF Posted July 2, 2022 Share Posted July 2, 2022 Try a decoder reset by writing value 8 to CV8, noting that you will have to change the address back from the default (3) to your chosen address.R8107 is a Class A4. Link to comment Share on other sites More sharing options...
ColinB Posted July 2, 2022 Share Posted July 2, 2022 Actually James I had exactly the same problem, with a Duchess though. I tried everything to fix it. In the end the only thing that seemed to make sense was a suggestion by 96RAF. The decoder was drawing too much current so the sound shut down. In the end I came to the conclusion it was something to do with the motor in that loco as that was the only thing I didn't change. I even tried different TTS decoders in the same loco and got the same effect. So what I suggest is, if you have another loco that takes an 8 pin decoder put it in there and see if it works ok. Eventually with mine I fitted a full blown Zimo sound decoder, which worked perfectly and moved the TTS decoder to one of my other locos where it also works perfectly. I should have changed the motor to see if that was the fault but in the end I gave up. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 3, 2022 Share Posted July 3, 2022 Let us know which loco you have it in James and, given it is drawing too much current as Colin and Rob suggest, we may be able to give advice on servicing to reduce the current. PS. Mods, what about adding to the title “ …… TTS Sound Cutting Out” please Link to comment Share on other sites More sharing options...
ColinB Posted July 3, 2022 Share Posted July 3, 2022 I will add mine was a brand new loco. I would have returned it to Hornby but I was unsure if was just something to do with my layout. Sometimes it cut out after one circuit, sometimes more. Link to comment Share on other sites More sharing options...
