StephenE Posted August 20, 2012 Share Posted August 20, 2012 Does anyone know if you need to have your locomotives facing the same way to double head on the Elite? I would like to run my S Class diesel locomotives back to back if possible (looks a touch more realistic) Also how many locos can make up a consist on the Elite controller? Regards and thanks Stephen Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 20, 2012 Share Posted August 20, 2012 Should be easy to operate them back to back - just reverse the direction of one loco - see page 43 of the 1.41 manual on how to do this. Interesting that the manual doesn't specify more than 2 locos in the consist instructions, although the Select can do 3. I'd just follow the instructions and see what happens if you try to add a third. Link to comment Share on other sites More sharing options...
poliss Posted August 20, 2012 Share Posted August 20, 2012 Yes, you can have locos back to back. There are several ways to do it depending on what decoder you are using. For a basic consist you just change the default direction of one loco as per the manual. Link to comment Share on other sites More sharing options...
