vickyP2 Posted January 7, 2023 Share Posted January 7, 2023 Hi all,I have sadly broken off and lost a handrail from my Hornby Class 71 electric.I was wondering if there was any way to obtain a replacement for it? Ie, by calling Hornby or tackling the spares store?Thanks! Link to comment Share on other sites More sharing options...
Bulleidboy Posted January 7, 2023 Share Posted January 7, 2023 Your best bet might be to make one from a short length of wire and paint it. There are no handrails on the service sheet, and I had a quick look on ebay and there are no Class 71 bodies listed. I assume it's white - have you searched your layout? Link to comment Share on other sites More sharing options...
Potterton Posted January 8, 2023 Share Posted January 8, 2023 Following on from Bulleidboys advice above, I've used fuse wire with considerable results in the past. Various thickness for different jobs. It's also exceedingly pliable and easily shaped. Link to comment Share on other sites More sharing options...
atom3624 Posted January 8, 2023 Share Posted January 8, 2023 If you have a stapler, check out their size cf what's required, or simply trim and reshape with pliers.Al. Link to comment Share on other sites More sharing options...
vickyP2 Posted January 9, 2023 Author Share Posted January 9, 2023 Thanks for the suggestion chaps. Sounds like wire is a good shout as are staples. I shall have a go with some wire first. Annoying its happened but could be much worse of course. Link to comment Share on other sites More sharing options...
What About The Bee Posted January 9, 2023 Share Posted January 9, 2023 Hi VickyP2Under the assumption that some other handrails are still on the model, measure them with a caliper. Calipers are available at almost ever home improvement store and are not terribly expensive.When replacing handrails, be aware that craft wire comes in various gauges, and therefore, you can closely match the size of the existing rails. Craft wire also comes in various colors.It will not do to simply replace the handrails. You should replace them with the proper size! At least in my mind, attention to detail provides a better result.Cheers!Bee Link to comment Share on other sites More sharing options...
