stevecamden Posted August 29, 2012 Share Posted August 29, 2012 I have a signal ( 2nd port) on the R8247 which will not respond to the signal command in the Railmaster programme script. Actually, I can set it from STOP to CLEAR once, but never back to STOP again through a script. I can set it STOP/CLEAR/STOP manually without a problem. The other port ( where I have a light signal) works fine STOP/CLEAR manually and through a railmaster script. Was wondering if anyone else has observed this conundrum? Link to comment Share on other sites More sharing options...
LMSTim Posted August 29, 2012 Share Posted August 29, 2012 If it's a solenoid operated signal (e.g. home or distant) are you leaving enough time for the accessory decoder to charge up? Although that shouldn't really be an issue. I have a layout with many signals and drive them through RailMaster (also points) and they set correctly. All are powered through the R8247 decoder. If it works manually when clicking the signal on the screen then it certainly should work within programs. If you still have no joy then you should send a help request from within RailMaster to Hornby. They will then also get your plan and the program you are working on and will be able to test it for you at their end or see if there is something obviously wrong. Link to comment Share on other sites More sharing options...
stevecamden Posted August 30, 2012 Author Share Posted August 30, 2012 Yes, its a light signal - works fine on/off when I click it on the screen. Just won't accept the programme line to set clear or stop. More investigation needed!!! Link to comment Share on other sites More sharing options...
stevecamden Posted August 30, 2012 Author Share Posted August 30, 2012 Discovered what the problem is. The signal had a reverse polarity checked as I didn't want to move the wires over, this works fine if you operate manually the signals from Railmaster but if you write a programme it doesn't like it. Guess, there is a bug in there somewhere. Anyway, have reversed the wires and unchecked the box and all is ok now Link to comment Share on other sites More sharing options...
LMSTim Posted September 3, 2012 Share Posted September 3, 2012 I have a large layout with lots of signals and points, many of which are wired in reverse so I set reverse polarity on the plan settings. I've get a few programs which switch points and signals and all of them work fine, reverse polarity or not. In fact I'm just written a small program to test the problem you were having and, with reverse polarity set, it sets the signals correctly every time. I'm running the latest RailMaster 1.40. And the Elite is in Standard mode on firmware 1.3 (I haven't updated the firmware yet). Link to comment Share on other sites More sharing options...
stevecamden Posted September 3, 2012 Author Share Posted September 3, 2012 Well that is even more interesting as I have updated to the so called latest release ( 1.41) and do get the problem and the only way I can make the signals operate from a programme is to make sure the reverse polarity isn't checked..... Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 3, 2012 Share Posted September 3, 2012 Suggest you get in touch with the RM help people. Link to comment Share on other sites More sharing options...
LMSTim Posted September 3, 2012 Share Posted September 3, 2012 You should send Hornby a Help Request from the software. Then they can see your plan and how it's been set up. They'll get to the bottom of it. They are very good. Link to comment Share on other sites More sharing options...
stevecamden Posted September 3, 2012 Author Share Posted September 3, 2012 Its not an 'issue' for me as I just rewired the signals and unchecked the reverse polarity box. Link to comment Share on other sites More sharing options...
poliss Posted September 3, 2012 Share Posted September 3, 2012 Ah, you've 'reversed the polarity of the neutron flow' then? :-) Link to comment Share on other sites More sharing options...
stevecamden Posted September 3, 2012 Author Share Posted September 3, 2012 Yes Polis - with my sonic screwdriver Link to comment Share on other sites More sharing options...
