Tee1707818014 Posted August 31, 2012 Share Posted August 31, 2012 Does anyone know how to get the above to appear correctly placed when you reduce the size of the layout? At present if I use the 75% or 50% the point numbers don't position correctly by the points and the signal numbers disappear altogether. I have the latest updates & 1.41 on the elite. I have also requested help via the button on rail master. Link to comment Share on other sites More sharing options...
Tee1707818014 Posted September 3, 2012 Author Share Posted September 3, 2012 Had a responce from RailMaster support: Dear RailMaster user We have looked at this issue and a resolution will be available in the next official update (1.41) which will be released very soon. Your RailMaster system should install this update automatically at the appropriate time. Regards Hornby RailMaster Support Team Link to comment Share on other sites More sharing options...
stevecamden Posted September 3, 2012 Share Posted September 3, 2012 Presumably, they don't mean the 'latest' version that can be downloaded from the website as this 'hasn't' cured the problem that you highlighted. Link to comment Share on other sites More sharing options...
LMSTim Posted September 3, 2012 Share Posted September 3, 2012 You can turn off the point and signal numbers anyway in Settings by unchecking "Show point numbers on plan". There's really no need to see the point numbers as RailMaster handles all of that for you. Gone are the days of having to have printed lists of loco IDs and point numbers so that you can select them by number on the DCC controller. Link to comment Share on other sites More sharing options...
Tee1707818014 Posted September 3, 2012 Author Share Posted September 3, 2012 Comes in handy though when you are going to have 55 points & 37 signals on two levels over a w shape with two helixes, as an ongoing layout project, since March which included the building of a 4m x 5m shed to house it all in. Link to comment Share on other sites More sharing options...
