forester Posted December 1, 2011 Author Share Posted December 1, 2011 Shame they didn't proceed with the plan to "unrebuild" (correct usage of the term this time!) preserved Holland America Line into an original Merchant Navy. We could have seen most of the liveries you mentioned over a period of time. Link to comment Share on other sites More sharing options...
mortehoe Posted December 2, 2011 Share Posted December 2, 2011 forester said:Shame they didn't proceed with the plan to "unrebuild" (correct usage of the term this time!) preserved Holland America Line into an original Merchant Navy. We could have seen most of the liveries you mentioned over a period of time. Hi Forester,I don't keep up with the full size stuff, I have enough trouble keeping up with the 4mm scale world. Talk of reverting a preserved MN back to air smoothed was kicked about for years, but with my limited knowledge of heavy engineering, it would probably be easier to start from new. A new set of driving wheels would be required ( rebuilds have the large counter balance weights ). Although the frames were kept, I don't know how much butchery took place during rebuilding, and whether, the frames would stand the act of being reverted back to original form. One for LC&DR to ponder over. Link to comment Share on other sites More sharing options...
LCDR Posted December 2, 2011 Share Posted December 2, 2011 mortehoe said:forester said:Shame they didn't proceed with the plan to "unrebuild" (correct usage of the term this time!) preserved Holland America Line into an original Merchant Navy. We could have seen most of the liveries you mentioned over a period of time. Hi Forester,I don't keep up with the full size stuff, I have enough trouble keeping up with the 4mm scale world. Talk of reverting a preserved MN back to air smoothed was kicked about for years, but with my limited knowledge of heavy engineering, it would probably be easier to start from new. A new set of driving wheels would be required ( rebuilds have the large counter balance weights ). Although the frames were kept, I don't know how much butchery took place during rebuilding, and whether, the frames would stand the act of being reverted back to original form. One for LC&DR to ponder over.Glad to oblige!Ideally the retro-rebuild ought to address those features that OVSB wanted to include but was prevented from doing by the War. Yes to the Air Smooth Casing, Yes to the High Boiler Pressure and Thermic Syphons, Yes to three cykinders and outside admission, No to chain driven valve gear, and Yes to rotary cam valve gear (Caprotti?) instead. Is some ways the Merchant Navys should have been a precursor to 71000. I am not 100% certain, but I don't believe the balance weights were cast on to the wheels of the rebuilds so ought to be removable. If not there may be some WC wheels that could be used. The frames were not significantly altered. If you consider the work required to restore one from 'Barry' condition the work involved would be similar either way.It is certain that the MN kettle was one of the best ever built, and a MN in good condition was a magnificent machine. Jarvis' rebuild turned it from supurb to unbeatable, so other than nostalgia or the chance to vindicate OVSB as I say above, the 'un-rebuild' is not likely to attract much support. (Now hopefully someone will prove me wrong!!) Link to comment Share on other sites More sharing options...
mortehoe Posted December 2, 2011 Share Posted December 2, 2011 LC&DR said:Glad to oblige!Ideally the retro-rebuild ought to address those features that OVSB wanted to include but was prevented from doing by the War. Yes to the Air Smooth Casing, Yes to the High Boiler Pressure and Thermic Syphons, Yes to three cykinders and outside admission, No to chain driven valve gear, and Yes to rotary cam valve gear (Caprotti?) instead. Is some ways the Merchant Navys should have been a precursor to 71000. I am not 100% certain, but I don't believe the balance weights were cast on to the wheels of the rebuilds so ought to be removable. If not there may be some WC wheels that could be used. The frames were not significantly altered. If you consider the work required to restore one from 'Barry' condition the work involved would be similar either way.It is certain that the MN kettle was one of the best ever built, and a MN in good condition was a magnificent machine. Jarvis' rebuild turned it from supurb to unbeatable, so other than nostalgia or the chance to vindicate OVSB as I say above, the 'un-rebuild' is not likely to attract much support. (Now hopefully someone will prove me wrong!!)I'm with you on this one, I hope some one proves us both wrong. Link to comment Share on other sites More sharing options...
Postman Prat Posted December 2, 2011 Share Posted December 2, 2011 Hi Where's yu bin, Mortehoe?? I put an extra special joke in 'Wishes' and you either missed it or you're still laughing at it!!!Why unrebuild a Merchant - just stick Merchant nameplates on a West Country. They're only boxes so no-one will notice the difference!! Link to comment Share on other sites More sharing options...
LCDR Posted December 3, 2011 Share Posted December 3, 2011 I would. Link to comment Share on other sites More sharing options...
mortehoe Posted December 3, 2011 Share Posted December 3, 2011 Do you know what, I think I would, devoid of name plates, and number. They were big beasties. Link to comment Share on other sites More sharing options...
Postman Prat Posted December 4, 2011 Share Posted December 4, 2011 Be like the differences between a size 9 shoebox and a size 10!! Link to comment Share on other sites More sharing options...
LCDR Posted December 4, 2011 Share Posted December 4, 2011 Ignore him Mortehoe, you can expect nuffing better from anyone from norf of the Tees. We who come from sowf ov Watford are much more discerning, ain't we! Link to comment Share on other sites More sharing options...
mortehoe Posted December 4, 2011 Share Posted December 4, 2011 Me thinks that PP is becoming, somewhat, a Bounder and a Cad. Link to comment Share on other sites More sharing options...
Postman Prat Posted December 4, 2011 Share Posted December 4, 2011 Becoming.....???Did you like the knotting joke in 'wishes'mortehoe said:Me thinks that PP is becoming, somewhat, a Bounder and a Cad. Link to comment Share on other sites More sharing options...
mortehoe Posted December 5, 2011 Share Posted December 5, 2011 Hi PP, missed 'em, just read them, rib ticklers, to say the least. Oh yes, you forgot, the wallet might be coming out three times next year. if a get together can be organised, the beers and pies are on me. So arm yourself with freeing oil and a large crowbar. Link to comment Share on other sites More sharing options...
Bulleidboy Posted December 5, 2011 Share Posted December 5, 2011 HiI noticed on this mornings MRE, that they are convinced that Hornby will produce a Merchant Navy in original form. Link to comment Share on other sites More sharing options...
LCDR Posted December 5, 2011 Share Posted December 5, 2011 They would!! Just when the paint has dried on my Golden Arrow Kits / Hornby MN & BB combo Elders Fyffes. Ah well I can look forward to a BR blue Clan Line maybe? Link to comment Share on other sites More sharing options...
Bulleidboy Posted December 6, 2011 Share Posted December 6, 2011 Hi LC&DRDon't start me off again! If you want a blue M/N, can you wish for a name that Hornby have not yet produced. It still grates that I have two Lamport & Holt Lines in my collection. Link to comment Share on other sites More sharing options...
mortehoe Posted December 6, 2011 Share Posted December 6, 2011 Hi bulleidboy, nice pun there " grates ", see where your going with this. I hope you are right, but hope there is a delay, otherwise 2012 will be a very expensive year for me. As long as it's blue, not bothered about names, I will just re-name a pair. Link to comment Share on other sites More sharing options...
LCDR Posted December 7, 2011 Share Posted December 7, 2011 bulleidboy said:Hi LC&DRDon't start me off again! If you want a blue M/N, can you wish for a name that Hornby have not yet produced. It still grates that I have two Lamport & Holt Lines in my collection.It would help if I could get the names right - for Elders Fyffes read Elder Dempster Lines, -- senility sets in! I also have two Clan Lines already, a Wrenn one and a modern Hornby one, but an air smoothed one would certainly find a place in my collection. Link to comment Share on other sites More sharing options...
Postman Prat Posted December 7, 2011 Share Posted December 7, 2011 The way you've been going on about the 'Spam Cans' makes me think senility set in a long time ago!!!!! Link to comment Share on other sites More sharing options...
UBoat Posted December 8, 2011 Share Posted December 8, 2011 I wouldn't be surprised if an Unrebuilt MN is release soon as I've got a Millholme MN in SR Mallachite, BR Green and am working on a BR Blue.On previous occasions I've finished building kits of T9, M7, Q1 and Rebuilt MN, to have Ready-to-run release soon afterwards. Still waiting for Q, S15 and U though. Link to comment Share on other sites More sharing options...
LCDR Posted December 9, 2011 Share Posted December 9, 2011 UBoat said:I wouldn't be surprised if an Unrebuilt MN is release soon as I've got a Millholme MN in SR Mallachite, BR Green and am working on a BR Blue.On previous occasions I've finished building kits of T9, M7, Q1 and Rebuilt MN, to have Ready-to-run release soon afterwards. Still waiting for Q, S15 and U though.You and me both! In my 'to do box' I have two SEF kits for a pair of 'U1's, a pair of 'C's, a Branchlines 'O1', A NNK '4Sub', a MTK '4EPB', three Kirk/Ashby '2Bils', a DC Kits 6S, and a 2H, a Golden Arrow Z, and assorted Triang L1s, Sir Dinadans etc. for butchery to make Ls, D1s E1s and S15s. I also have some Airfix 14xx and HD R1s with a view to cobbling together some Hs. As soon as I start assembling them one of the manufacturers will make one. That has already happened with a Fairburn 4MT, a pair of 2EPBs, and two SEF Cs when they have been announced by the competition, and a pair of wide chimney V by Hornby, plus of course repainting Dinadans into BR liveries. Good job I enjoy making them. Link to comment Share on other sites More sharing options...
mortehoe Posted December 9, 2011 Share Posted December 9, 2011 LC&DR said:You and me both! In my 'to do box' I have two SEF kits for a pair of 'U1's, a pair of 'C's, a Branchlines 'O1', A NNK '4Sub', a MTK '4EPB', three Kirk/Ashby '2Bils', a DC Kits 6S, and a 2H, a Golden Arrow Z, and assorted Triang L1s, Sir Dinadans etc. for butchery to make Ls, D1s E1s and S15s. I also have some Airfix 14xx and HD R1s with a view to cobbling together some Hs. As soon as I start assembling them one of the manufacturers will make one. That has already happened with a Fairburn 4MT, a pair of 2EPBs, and two SEF Cs when they have been announced by the competition, and a pair of wide chimney V by Hornby, plus of course repainting Dinadans into BR liveries. Good job I enjoy making them.Quick, LC&DR, make one of your Bils, and dash out and buy a 4-Cor, and who knows ?????? Link to comment Share on other sites More sharing options...
LCDR Posted December 9, 2011 Share Posted December 9, 2011 Rest assured I'm on with it at the moment, but with Branchline etched brass 2Hal sides instead. Can't promise on the 4Cor, they were rarely on the SED, and the 2Bil only worked a limited diagram to Orpington and back in rush hours. 2Hals were the units I need, I already have a Phoenix one made, and one of their 'Tin Hal' kit in waiting. Link to comment Share on other sites More sharing options...
Postman Prat Posted December 9, 2011 Share Posted December 9, 2011 Hi LC&DRYou could have built some of them if you hadn't been banging on about 'big spam-cans'!!! Link to comment Share on other sites More sharing options...
Postman Prat Posted December 9, 2011 Share Posted December 9, 2011 What the blazes is going on here? Everything is going 'out of turn' Link to comment Share on other sites More sharing options...
the ferret Posted December 11, 2011 Share Posted December 11, 2011 LC&DR said:Rest assured I'm on with it at the moment, but with Branchline etched brass 2Hal sides instead. Can't promise on the 4Cor, they were rarely on the SED, and the 2Bil only worked a limited diagram to Orpington and back in rush hours. 2Hals were the units I need, I already have a Phoenix one made, and one of their 'Tin Hal' kit in waiting.Hi, LC&DR,Are you a Southern Railways Group member? Link to comment Share on other sites More sharing options...
