LukiP Posted September 19, 2012 Share Posted September 19, 2012 I'm fairly new to railway moddeling and am looking into the select dcc controller. It sounds really good to me and I fully understand how to program locomotives but I'm very confused about point motors and accesories... :( I've read bits and pieces from various web sites and dont understand if i need the decoder or any thing like that... I wiuld be very greatful for any help any one could give me. Thx. Link to comment Share on other sites More sharing options...
Flashbang Posted September 19, 2012 Share Posted September 19, 2012 Hi You have two options... One is to use DCC for everything. Then you will need a Point Accessory Decoder (PAD) Hornby part R8247. This connects to the DCC system via the rails or a DCC bus pair of wires if a bus is used. The Hornby PAD has four separate outputs so four solenoid motors can be fed. In fact you can connect two motors to one output where a cross-over pair of points are to be moved together. The Select as supplied with the 1.0Amp power supply really inst up to operating a layout and PADs too. You can replace the power supply unit with the 4.0Amp version and this will be better. Hornby part P9300. https://www.hornby.com/shop/digital/p9300-digital-15v-4-amp-transformer/ The other alternative is to use the Select as the DCC loco control and operate all the points by conventional (analogue) 16 volts ac feed from a totally separate power supply. Each point is then worked by a R044 black passing contact lever or a sprung top centre off toggle switch To note: You mention you are conversant with programming locos. Do be aware the Select cannot alter CVs other than the few its pre programmed to do - Address number 1 to 59. Normal direction of travel. Acceleration and deceleration rates. If you wish to adjust CVs to obtain the best performance from your locos, then you will need the Elite or other DCC system tyhast capable of writing CVs. Link to comment Share on other sites More sharing options...
LukiP Posted September 19, 2012 Author Share Posted September 19, 2012 Flashbang said: Hi You have two options... One is to use DCC for everything. Then you will need a Point Accessory Decoder (PAD) Hornby part R8247. This connects to the DCC system via the rails or a DCC bus pair of wires if a bus is used. The Hornby PAD has four separate outputs so four solenoid motors can be fed. In fact you can connect two motors to one output where a cross-over pair of points are to be moved together. The Select as supplied with the 1.0Amp power supply really inst up to operating a layout and PADs too. You can replace the power supply unit with the 4.0Amp version and this will be better. Hornby part P9300. https://www.hornby.com/shop/digital/p9300-digital-15v-4-amp-transformer/ The other alternative is to use the Select as the DCC loco control and operate all the points by conventional (analogue) 16 volts ac feed from a totally separate power supply. Each point is then worked by a R044 black passing contact lever or a sprung top centre off toggle switch To note: You mention you are conversant with programming locos. Do be aware the Select cannot alter CVs other than the few its pre programmed to do - Address number 1 to 59. Normal direction of travel. Acceleration and deceleration rates. If you wish to adjust CVs to obtain the best performance from your locos, then you will need the Elite or other DCC system tyhast capable of writing CVs. Link to comment Share on other sites More sharing options...
LukiP Posted September 19, 2012 Author Share Posted September 19, 2012 Thanks so much, i think i can follow it slightly better now. Is it cheaper to controll all the accessories through the select or to controll them seperately? And where can i buy a sufficient power supply if i use switches? Thanks though :) :) Link to comment Share on other sites More sharing options...
LukiP Posted September 19, 2012 Author Share Posted September 19, 2012 Sorry... Not sure how that copy of you post got there... :/ Link to comment Share on other sites More sharing options...
Gregd99 Posted September 19, 2012 Share Posted September 19, 2012 it is definitely cheaper to use momentary contact switches than an accessory decoder. in my opinion dcc control of points really only makes sense if you want to control your layout from a pc.... but this needs an elite not a select. the other reason I have heard put forward is if you control your layout form a walkabout throttle. there is no right./wrong answer. it depends on your interests. Link to comment Share on other sites More sharing options...
Flashbang Posted September 19, 2012 Share Posted September 19, 2012 Hi For separate power supplies suitable to operate a solenoid point motors you will need to look beyond Hornby, though if you upgraded and used the 4.0amp PSU I linked to in an earlier post to feed the Select you can then use the 15volt dc outlet on the Select for this. But not with the Selects supplied 1.0Amp PSU. Unfortunately, as this forum is run by Hornby we are not permitted to post links to other suppliers! But for suitable 16 to 24 volt ac PSUs (Power Supply Units) look at Gaugemaster, Rail room Electronics or simply Google 16 volt PSU. You would need a PSU that can provide a minimum of 1.0Amp or more at 16-24 volts ac. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 19, 2012 Share Posted September 19, 2012 If you want to learn more about the Select and the PAD, you can find their manuals under Downloads in the menus on the left of this site, then Instruction Manuals, then Digital Instruction Manuals. While you are there, you can look at the Elite manual and see how much more capable it is over the Select. Link to comment Share on other sites More sharing options...
Trackie Posted September 30, 2012 Share Posted September 30, 2012 Hi, I'm new to model railways and this is my first post. Recently bought a Hornby kit to build the layout on the Trakmat - with all the extension packs and seven surface mounted points motors to go with it. It has the Select controller. I have the locos working but the points motors don't work, even with no locos on the track. I can get them to work if I hold them in my hand, but as soon as I connect them to the track they will throw the points out, but not bring them back. They seem to be not strong enough to do the job. Is this because the power supply in the Select is too small? I note a previous post by Flashbang: "The Select as supplied with the 1.0Amp power supply really inst (isn't?) up to operating a layout and PADs too. You can replace the power supply unit with the 4.0Amp version and this will be better. Hornby part P9300. https://www.hornby.com/shop/digital/p9300-digital-15v-4-amp-transformer/" I would appreciate any comments. If I was to buy the P9300 to get up to 4 amps I would like to be assured that it is all going to work. Thanks Link to comment Share on other sites More sharing options...
Rog RJ Posted September 30, 2012 Share Posted September 30, 2012 Trackie said: Hi, I'm new to model railways and this is my first post. Recently bought a Hornby kit to build the layout on the Trakmat - with all the extension packs and seven surface mounted points motors to go with it. It has the Select controller. I have the locos working but the points motors don't work, even with no locos on the track. I can get them to work if I hold them in my hand, but as soon as I connect them to the track they will throw the points out, but not bring them back. They seem to be not strong enough to do the job. Is this because the power supply in the Select is too small? I note a previous post by Flashbang: "The Select as supplied with the 1.0Amp power supply really inst (isn't?) up to operating a layout and PADs too. You can replace the power supply unit with the 4.0Amp version and this will be better. Hornby part P9300. https://www.hornby.com/shop/digital/p9300-digital-15v-4-amp-transformer/" I would appreciate any comments. If I was to buy the P9300 to get up to 4 amps I would like to be assured that it is all going to work. Thanks This same problem came up in another post the other day. Here is my reply A point operating one way but not the other can often be caused by having the common © wire crossed with one of the "direction" wires, either green or red. Hornby use black as the common on points. PS You will almost certainly have problems operating point motors directly from the Select with the standard power supply, it's just not powerful enough. Link to comment Share on other sites More sharing options...
Trackie Posted September 30, 2012 Share Posted September 30, 2012 Hi Roj, Thanks for that - I had the black wire in the wrong place. I did as you suggested and all is working fine (at least for the one points motor I have installed so far). Would be nice if they had put that in the manual. They also talk about +ve and -ve wires in the manual but don't say which colour is which. Regards Geoff Link to comment Share on other sites More sharing options...
Trackie Posted October 1, 2012 Share Posted October 1, 2012 I have a question about the use of the surface mounted points motor with the Select Controller. When I select a loco with the Select Controller it always show the direction of travel on the controller (ie one of the direction keys is lit up). However, when I select a points motor, it doesn't show which direction it is set (none of the direction keys are lit). I then have to make a visual check on the actual points to see if I have pressed the correct direction arrow to change the setting. Does anyone else think this is a problem? I am starting to think there might be a convention - eg the left arrow means the points motor pushes it's arm out, the right brings it in, but as I have only installed one motor so far I am not sure. It would be nice to have the arrow lit up showing the current state of the motor when it is selected. Link to comment Share on other sites More sharing options...
Flashbang Posted October 1, 2012 Share Posted October 1, 2012 Hi According to page 24 of the Select manual headed 'Operation', one of the Selects direction arrow LEDs should light for approx. 1 second to show the points direction selected. Link to comment Share on other sites More sharing options...
Dwarfboysim Posted October 12, 2012 Share Posted October 12, 2012 Definitely get the 4 AMP power supply for the Select. I was then able to control 20 sets of points happily. Thanks, Dwarfboysim Rog (RJ) said: Trackie said: Hi, I'm new to model railways and this is my first post. Recently bought a Hornby kit to build the layout on the Trakmat - with all the extension packs and seven surface mounted points motors to go with it. It has the Select controller. I have the locos working but the points motors don't work, even with no locos on the track. I can get them to work if I hold them in my hand, but as soon as I connect them to the track they will throw the points out, but not bring them back. They seem to be not strong enough to do the job. Is this because the power supply in the Select is too small? I note a previous post by Flashbang: "The Select as supplied with the 1.0Amp power supply really inst (isn't?) up to operating a layout and PADs too. You can replace the power supply unit with the 4.0Amp version and this will be better. Hornby part P9300. https://www.hornby.com/shop/digital/p9300-digital-15v-4-amp-transformer/" I would appreciate any comments. If I was to buy the P9300 to get up to 4 amps I would like to be assured that it is all going to work. Thanks This same problem came up in another post the other day. Here is my reply A point operating one way but not the other can often be caused by having the common © wire crossed with one of the "direction" wires, either green or red. Hornby use black as the common on points. PS You will almost certainly have problems operating point motors directly from the Select with the standard power supply, it's just not powerful enough. Link to comment Share on other sites More sharing options...
VirginPendolino. Posted October 19, 2012 Share Posted October 19, 2012 so with the Accessory Decoder Hornby part R8247. can i connect point motors and signals to it to control with my dcc controller? Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 19, 2012 Share Posted October 19, 2012 VP, for a start, you can control points via the R8247 with your Select, although note from earlier posts here that some suggest you need the 4Amp power supply to do it reliably. For signal control, you may need to reprogram the 8247 to give a long signal output, not just the pulse produced for points. Unfortunately, you can't do this with the Select, you would have to find someone with an Elite or similar to do that for you. Link to comment Share on other sites More sharing options...
