grumpy old man Posted September 19, 2012 Share Posted September 19, 2012 Hi I have just purchased the R 3140 Northern Class with the intention of fitteing a R8249 decoder however there is no instructions on how to remove the body shell can anybody help before I contact the help Desk Thanx Link to comment Share on other sites More sharing options...
poliss Posted September 19, 2012 Share Posted September 19, 2012 Here you go. http://s374444733.websitehome.co.uk/class-142/index.htm The guide also shows how to add LED lights should you so wish. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 19, 2012 Share Posted September 19, 2012 Isn't there an service sheet with the model that includes how to remove the body. If not, look up service sheets under Downloads in the menus on the left. Link to comment Share on other sites More sharing options...
grumpy old man Posted September 19, 2012 Author Share Posted September 19, 2012 Fishmanoz said: Isn't there an service sheet with the model that includes how to remove the body. If not, look up service sheets under Downloads in the menus on the left. Link to comment Share on other sites More sharing options...
poliss Posted September 19, 2012 Share Posted September 19, 2012 Have you tried finding service sheets on this website Fishy? They're listed by service sheet number rather than loco type or R number and there are only 10 sheets per page. It takes an awful lot of work for what should be a simple operation. The most you should have to do is put the R number in the search box and it should point you toward the service sheet. It does with other models. Link to comment Share on other sites More sharing options...
Flashbang Posted September 19, 2012 Share Posted September 19, 2012 Hi I have yet to find a service sheet from any UK outline loco manufacturer, and that includes Hornby, that in detail explains exactly how to remove a particular locos body shell from the chassis! e.g. Locate the 4 screws marked as 'xx' remove then gently ease the body off of the chassis. Or remove umpteen screws marked 'xxx', insert thin card shims along the body and then ease the body shell from the chassis etc. Link to comment Share on other sites More sharing options...
poliss Posted September 19, 2012 Share Posted September 19, 2012 A certain Japanese company uses full colour photographs and gives detailed instructions on how to remove body shells. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 19, 2012 Share Posted September 19, 2012 poliss said: Have you tried finding service sheets on this website Fishy? They're listed by service sheet number rather than loco type or R number and there are only 10 sheets per page. It takes an awful lot of work for what should be a simple operation. The most you should have to do is put the R number in the search box and it should point you toward the service sheet. It does with other models.Ys poliss, I know. I usually pull down the soft copy of the sheet for my locos - easier to find it filed on the computer than look for the piece of paper. There's about 15 pages of them to search through too but at least you can usually figure it out from the file title although there can be multiple file names where there are different versions of the same model, then you have to open them to find which one. Link to comment Share on other sites More sharing options...
grumpy old man Posted September 20, 2012 Author Share Posted September 20, 2012 Thanx for all your answers I have now been able to solve my problem Regards Link to comment Share on other sites More sharing options...
