M. Matthews Posted May 21, 2023 Share Posted May 21, 2023 There is a small loco that I wish to give the HM7000 treatment. Room is extremely limited and after assessing the space, it looks like I can only fit the speaker without an enclosure. Does anybody have any experience of what the resulting sound quality might be like?Thanks Link to comment Share on other sites More sharing options...
SteveM6 Posted May 21, 2023 Share Posted May 21, 2023 Short answer - it will sound terrible. They are designed to work with an enclosure. Link to comment Share on other sites More sharing options...
M. Matthews Posted May 21, 2023 Author Share Posted May 21, 2023 I thought as much. Thanks anyway! Link to comment Share on other sites More sharing options...
My name is Bond Posted May 22, 2023 Share Posted May 22, 2023 You receive an assortment of speaker enclosures with the sound decoder. Maybe one could be used or modified? Link to comment Share on other sites More sharing options...
Rallymatt Posted May 22, 2023 Share Posted May 22, 2023 Someone has 3D printed a super small enclosure to add sound to a TT:120 Class 08 shunter. You could test a speaker without an enclosure just to confirm it is not desirable. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 22, 2023 Share Posted May 22, 2023 Any detail on how they did that Rm?I’m assuming an -8TXS with the plug cut off and 6 pins terminating the appropriate cables. But then where is it fitted, let alone the speaker. Link to comment Share on other sites More sharing options...
Rallymatt Posted May 23, 2023 Share Posted May 23, 2023 Fishy, here is YT link Quite inventive although long term the smaller motor clips could be an issue, depends on the properties of the 3D print resin. Link to comment Share on other sites More sharing options...
96RAF Posted May 23, 2023 Share Posted May 23, 2023 A pity we don’t have any TT120 service sheets to refer to.Could not the larger clip seen in the video just be cropped shorter to match the new print items, thus providing space.The Hornby speaker drives from both sides apparently so an enclosure is essential to separate the sound phasing. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 23, 2023 Share Posted May 23, 2023 Thanks Rm, interesting.He’s using a Zimo MS500N decoder at 14x10x2.6mm 6-pin which will fit into the socket in the 08 with the challenge being the speaker (added this to avoid having to go the YT to get that detail). It’s around the same price as the -8TXS which is much larger at 18x10x7mm. You could always put the speaker in a wagon behind. Link to comment Share on other sites More sharing options...
Rallymatt Posted May 23, 2023 Share Posted May 23, 2023 There is an updated video with more of what Richard has done to achieve this.In addition to your idea of trimming down the motor clip Rob, I would think it could be possible to cut down the smaller speaker enclosure too or make one from plasicard, for those of us without a 3D printer 😁Although, making a new motor clip does mean you have an option to return to original if you needed to. I would be more keen to get a stay alive in there though, ahead of sound. Link to comment Share on other sites More sharing options...
