grumpy old man Posted September 21, 2012 Share Posted September 21, 2012 Hi again After managing to get the body shell off the R3140 Northernrail (thanx to all those who gave info)I successfully installed the R8249 decoder. Problem I find that after running it then leaving it stood for a while (say 30 mins minimum ) I find that I need to put it back on the programming track to readdress it. I`v had no problems with any other of my locos that I have the R8249 fitted to Any help would be appreciated. I use both Select & Elite controllers and both are working ok Thanx Link to comment Share on other sites More sharing options...
poliss Posted September 21, 2012 Share Posted September 21, 2012 That should never happen. Have you got another decoder to try it with? Link to comment Share on other sites More sharing options...
Flashbang Posted September 21, 2012 Share Posted September 21, 2012 Hi Are you saying the decoder is self resetting back to its default address of 3? Hence the need to reprogram it. Is one system being used that is causing the problem - e.g. The Select is the one causing the problem or its the Elite? You know you cant have both connected to the rails or DCC bus wires, don't you? As Poliss says this is not correct. Sometimes and not often now, a decoder will reset to its default settings if there is a short circuit on the layout or sometimes a power surge is occurring at powering up the DCC system. But this is not common. Link to comment Share on other sites More sharing options...
grumpy old man Posted September 21, 2012 Author Share Posted September 21, 2012 Flashbang said: Hi Are you saying the decoder is self resetting back to its default address of 3? Hence the need to reprogram it. Is one system being used that is causing the problem - e.g. The Select is the one causing the problem or its the Elite? You know you cant have both connected to the rails or DCC bus wires, T don't you? As Poliss says this is not correct. Sometimes and not often now, a decoder will reset to its default settings if there is a short circuit on the layout or sometimes a power surge is occurring at powering up the DCC system. But this is not common.I Link to comment Share on other sites More sharing options...
grumpy old man Posted September 21, 2012 Author Share Posted September 21, 2012 Post a new reply... Link to comment Share on other sites More sharing options...
Flashbang Posted September 21, 2012 Share Posted September 21, 2012 Nothing said! :-( Link to comment Share on other sites More sharing options...
grumpy old man Posted September 21, 2012 Author Share Posted September 21, 2012 Hi I have just tried again to run the loco after a `rest period `of 1 hr but no luck I had to readdress to it to 9 yet again, it shows 3 on the select at start up and will not run at the default code 3 unless I address to this number. My controllers are used seperataly and not attached to the rails together. I address locos using the select controller. Also i did not originally mention that the loco has a high hummimg noise when running I have lubricated the areas as shown on the info sheet I am not quite sure if this is because it is a DMU as my other locos do not have this running noise. Hope this explains my problem clearly Thanx Link to comment Share on other sites More sharing options...
poliss Posted September 21, 2012 Share Posted September 21, 2012 Have you tried a different decoder? Check that the pins on the decoder aren't projecting through the bottom of the socket in the loco and short circuiting. Also check that no wires got fouled or damaged when you replaced the body shell. What are you using to connect the controllers to the track? If using a power clip or power track they must be the digital versions as the analogue types have a capacitor fitted which confuses the DCC 'signal'. You do know that you can plug the Select into the Elite and use the Select as a Walkabout controller? The Select power supply should be removed of course. Link to comment Share on other sites More sharing options...
grumpy old man Posted September 27, 2012 Author Share Posted September 27, 2012 poliss said: Have you tried a different decoder? Check that the pins on the decoder aren't projecting through the bottom of the socket in the loco and short circuiting. Also check that no wires got fouled or damaged when you replaced the body shell. What are you using to connect the controllers to the track? If using a power clip or power track they must be the digital versions as the analogue types have a capacitor fitted which confuses the DCC 'signal'. You do know that you can plug the Select into the Elite and use the Select as a Walkabout controller? The Select power supply should be removed of course. Link to comment Share on other sites More sharing options...
poliss Posted September 27, 2012 Share Posted September 27, 2012 Are you pressing the Black reply button Grumpy? The Red post reply works better. Link to comment Share on other sites More sharing options...
