geochoice Posted October 3, 2012 Share Posted October 3, 2012 Tried for ages to find the thread to wire my 56 to dcc. Can someone point me in the right direction, it is Railfreight and the body unclips, confusing amount of red and blacks to the motor area. Anypne please? Thanks. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 3, 2012 Share Posted October 3, 2012 I take it it is not a new model? All of the current ones seem to be at least DCC Ready. Link to comment Share on other sites More sharing options...
geochoice Posted October 3, 2012 Author Share Posted October 3, 2012 Nope not new fish, got code 56 090 on the side, light each end and a ringfield type motor but not same as the Riviera 56 I did. This one is black motor, one black and red go thro trailing bogie apart from that seems lots blacks and reds hum hum di dum..... Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 3, 2012 Share Posted October 3, 2012 I think the Service Sheet number is 229B and the reason for all of the extra wires is the lights at each end. The principle is still the same though - remove the reds from one motor brush and the blacks from the other. Connect them to the decoder reds and blacks. Then decoder orange and grey go to the motor brushes. You might want to also change the lights to be connected to white and yellow with the blue common return. BUT, yo Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 3, 2012 Share Posted October 3, 2012 To finish the last line: BUT you must make sure that the left motor brush is isolated from the chassis or you will fry the decoder. See other posts on how to isolate if needed. And poliss will get upset with me about EU regulations but I suggest you remove the capacitor and bead too. No need to worry about voided warranty on this one. Link to comment Share on other sites More sharing options...
geochoice Posted October 3, 2012 Author Share Posted October 3, 2012 Is that the screw on the left side of the black ring, under the soldered contacts I am supposed to remove? Thanks. Link to comment Share on other sites More sharing options...
poliss Posted October 3, 2012 Share Posted October 3, 2012 Nothing to do with EU regulations Fishy. It's the UK Communications Act 2003. It goes something like '..if your model railway interferes with your neighbours telly you will be transported to Aussie Tralia where you will be forced to watch Neighbours for 5 years non stop.... Link to comment Share on other sites More sharing options...
geochoice Posted October 3, 2012 Author Share Posted October 3, 2012 poliss said: Nothing to do with EU regulations Fishy. It's the UK Communications Act 2003. It goes something like '..if your model railway interferes with your neighbours telly you will be transported to Aussie Tralia where you will be forced to watch Neighbours for 5 years non stop.... That'll do nicely sir. And the fishes. Anyway about the offending screw? Is it that one? Link to comment Share on other sites More sharing options...
poliss Posted October 3, 2012 Share Posted October 3, 2012 Have you seen the the article about Ringfield motors on Brian Lambert's website? http://www.brian-lambert.co.uk/DCC.htm#Decoder Installation. Link to comment Share on other sites More sharing options...
Graskie Posted October 3, 2012 Share Posted October 3, 2012 poliss said: Nothing to do with EU regulations Fishy. It's the UK Communications Act 2003. It goes something like '..if your model railway interferes with your neighbours telly you will be transported to Aussie Tralia where you will be forced to watch Neighbours for 5 years non stop....I'm game for that if Kylie Minogue's still in it! Link to comment Share on other sites More sharing options...
poliss Posted October 3, 2012 Share Posted October 3, 2012 Nah, she moved to Melbourne with Madge. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 3, 2012 Share Posted October 3, 2012 I'm struggling a little with your screw description as I didn't mention one and I'm only looking at a black and white diagram but I think you are right. If there is a short to chassis problem to be fixed, it done by either isolating this screw with a plastic sleeve or replacing it with a nylon screw. As far as Neighbours and Kylie are concerned, the program hasn't been compulsory for over 10 years and you see more of Kylie than we do. In fact, you'll have trouble organising to get transported at all as a lot of our Government energy goes into stopping various refugees transporting themselves here via people smugglers. I know you have the problem too but at least trucks don't sink half way like some of the rotten boats do. Link to comment Share on other sites More sharing options...
geochoice Posted October 4, 2012 Author Share Posted October 4, 2012 Hi Fish. Well I removed the screw as there was an error read on the test track with it in place and now it is out the test track is not showing any error message. Next is to put something back in that doesn't conduct. Hopefully that was all tha was needed to cure the short. Apart that is from another decoder :-( cos I fried it with your fishes. As for Kylie, we don't see much of her here but you can have Jason back if you want. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 4, 2012 Share Posted October 4, 2012 Try doing a search on Ringfield conversion and you should find some complete instructions on how to do the isolation. Link to comment Share on other sites More sharing options...
geochoice Posted October 5, 2012 Author Share Posted October 5, 2012 Hi Fishy, Took out the left hand screw from motor as advised and separated the final red from the motor and attached to the chip, put it on test track and FLASH, frightened s*** out of me but turns out it was the lights contacting and cos no case on it looked like bonfire night !! Anyway all is sorted now and it goes lie a train (sic). Thanks for your help and advice, I must admit I am useless at this, dangerous even and instead of unsoldering all the wires I tend to cut and shut them cos my soldering isn't too neat, same end but easier (for me anyway). Enjoy all the fish. Geo Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 5, 2012 Share Posted October 5, 2012 Pleased it went well for you in the end and glad to be of help. Link to comment Share on other sites More sharing options...
