malang66 Posted November 11, 2012 Share Posted November 11, 2012 i've been told the select doesn't warrent nmra decoders so which decoder should you i use with the select controller!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Flashbang Posted November 11, 2012 Share Posted November 11, 2012 Hi The Hornby Select is not NMRA conformant, and as such may not work well with some decoders that are NMRA conformance! If you want to be 100% sure of good operation, then stick with the Hornby basic decoder R8249 or the Hornby Sapphire R8245. Or upgrade to the Elite then any make of decoder should work ok. Link to comment Share on other sites More sharing options...
malang66 Posted November 11, 2012 Author Share Posted November 11, 2012 Flashbang said:thanks flashbang so i'll be ok with the hornby one's then, just confused with all this should have stuck to analog lol. may update to elite if i grow my layout any bigger than the planned 1800 x 2220mm... Hi The Hornby Select is not NMRA conformant, and as such may not work well with some decoders that are NMRA conformance! If you want to be 100% sure of good operation, then stick with the Hornby basic decoder R8249 or the Hornby Sapphire R8245. Or upgrade to the Elite then any make of decoder should work ok. Link to comment Share on other sites More sharing options...
The son of Triangman Posted November 11, 2012 Share Posted November 11, 2012 I agree with Flashbang, use Hornby decoders with the Select or upgrade to an NMRA compliant console. Link to comment Share on other sites More sharing options...
Gregd99 Posted November 11, 2012 Share Posted November 11, 2012 +1 Link to comment Share on other sites More sharing options...
