Wandles Trains Posted November 15, 2012 Share Posted November 15, 2012 Hi all im thinking of buying a seuthe smoke unit 99 for some of my locos and i was just wondering if hornby dcc select gives of at least 8 volts. Thanks Matthew Link to comment Share on other sites More sharing options...
poliss Posted November 15, 2012 Share Posted November 15, 2012 Yes, but you'll need a powerful decoder such as the Sapphire. You'd probably be better off with the Elite or use the 4amp power supply for the Select as smoke units use a lot of power. Link to comment Share on other sites More sharing options...
Wandles Trains Posted November 15, 2012 Author Share Posted November 15, 2012 ok mate thanks i think il get the 4 amp power plug and get afew saphire decoders ordered Thanks again mate Link to comment Share on other sites More sharing options...
Blackbird Posted November 29, 2012 Share Posted November 29, 2012 Most compatible decoders have the ability to adjust the aux output (CV selection). So for smoke units it is often an advantage to have a lower output to be more realistic. Expensive (saphire) decoders and 4 amp supplies arn't allways necessary! Link to comment Share on other sites More sharing options...
Wandles Trains Posted December 1, 2012 Author Share Posted December 1, 2012 Blackbird said: Most compatible decoders have the ability to adjust the aux output (CV selection). So for smoke units it is often an advantage to have a lower output to be more realistic. Expensive (saphire) decoders and 4 amp supplies arn't allways necessary! Ok thanks for help mate Link to comment Share on other sites More sharing options...
poliss Posted December 1, 2012 Share Posted December 1, 2012 You can't alter output with the Select. Link to comment Share on other sites More sharing options...
