Is there a recommended build sequence for Pocher
96RAF
Go to solution Solved by ModelMan85,
The recommended build sequence is shown in the manual but you may wish to alter this to suit yourself whilst ensuring that you do not 'paint yourself into a corner' by building an assembly that relies upon a previous assembly to be complete first.
  • 5 weeks later...
  • Solution
Yes, you need to be careful doing that for that precise reason. It may mean you end up without access to screw on a component at a later stage and might be forced to dismantle, or find another method for assembling that component.
That said, everyone sees the challenge different, and part of the fun is finding a new technique or trick to get around a tricky stage.
  • Thanks 1
