doublepeg Posted November 28, 2012 Share Posted November 28, 2012 Has anyone fitted firebox flicker to a Hornby sound fitted loco? Did you manage to sync it with coal shovelling, where do you connect the flicker LED to? I really fancy having a go at it Link to comment Share on other sites More sharing options...
stevecamden Posted November 29, 2012 Share Posted November 29, 2012 This link might be useful: http://www.youchoos.co.uk/Index.asp?L1=Guides&Item=FireBoxLight Link to comment Share on other sites More sharing options...
Gregd99 Posted November 29, 2012 Share Posted November 29, 2012 if you use the sapphire/8245 decoder you can set function outputs to "flicker". possible values are:- 0 – steady state. 1 – strobe. 2 – flickering / random fast flash. 3 – steady flashing. see https://www.hornby.com/filelibrary/download/?FileID=138 Link to comment Share on other sites More sharing options...
Flashbang Posted November 30, 2012 Share Posted November 30, 2012 doublepeg said: Has anyone fitted firebox flicker to a Hornby sound fitted loco? Did you manage to sync it with coal shovelling, where do you connect the flicker LED to? I really fancy having a go at it Hi A) You need a decoder that supports CV alterations to the Function output. B) You need a DCC system that can write CVs The Hornby Select cannot do this! Link to comment Share on other sites More sharing options...
doublepeg Posted December 1, 2012 Author Share Posted December 1, 2012 Flashbang said: doublepeg said: Has anyone fitted firebox flicker to a Hornby sound fitted loco? Did you manage to sync it with coal shovelling, where do you connect the flicker LED to? I really fancy having a go at it Hi A) You need a decoder that supports CV alterations to the Function output. B) You need a DCC system that can write CVs The Hornby Select cannot do this! The decoder will be whatever is fitted to a Hornby sound loco as I don't want to loose the sound, I use the Hornby Elite. Link to comment Share on other sites More sharing options...
koo9 Posted December 1, 2012 Share Posted December 1, 2012 Well, be prepared to rewire the socket, it is a custom ESU decoder and a minimal connection board. Take the lid off and look first. :-( Link to comment Share on other sites More sharing options...
