Derek-1233089 Posted September 24 Share Posted September 24 I have a number of hairpin bends on my layout, however they are persistently problematic. The gap between the rails has a habit of becoming too narrow for the guide to pass through. My normal solution is to take the track section out and flex it a few times to get the necessary gap. But this is only ever a temporary solution. Does anyone else have this problem and have they found a permanent solution? Link to comment Share on other sites More sharing options...
Andy P. Posted September 24 Share Posted September 24 Are you talking about the R1 hairpins that require the squeeze standard straights (highlighted here: https://uk.scalextric.com/products/scalextric-hairpin-curve-track-accessory-pack-c8195 ) ? Non-Hornby cars i.e. Carrera will likely have trouble as the guide blades are longer, thicker and deeper (sounds mildly rude I know...) Standard Hornby Scalextric cars should be able to passe them with no problems. I have on the rare occasion seen some flaring at the beginning of a slot either of plastic or metal but nothing that wasn`t easy to fix permanently. If they are getting stuck at the beginning it could be the the tabs have rotated (they are square) and need reseating and pushed back in . See this for more: Otherwise I can`t see why the cars should bind unless the metal rails damage in some way (stepping on them is a good way to smash them down and have them pinch the guide blade) Good luck! Link to comment Share on other sites More sharing options...
