ColinB Posted 4 hours ago Share Posted 4 hours ago (edited) I don't know if people have the same issues I do with pulling off the worm gear off of a motor. I have bought many pullers ground them down to fit but none seem to work that well. So I bought a small puller Pasotim Pinion Puller from Amazon. It is small enough to fit the gap between the worm drive and the motor. Now in its virgin shape the gap is not big enough for the worm drive, so I filed the gap so it is bigger. Fits perfectly and because it is so small it is difficult not to do a square pull which is what normally bends the pin on the bigger ones. Edited 4 hours ago by ColinB Link to comment Share on other sites More sharing options...
atom3624 Posted 3 hours ago Share Posted 3 hours ago Colin, well done, and yes, it is a pain trying to find 'the one that works'. I've several which have failed, or not been suitable despite appearance. Al. Link to comment Share on other sites More sharing options...
96RAF Posted 1 hour ago Share Posted 1 hour ago Mine has a superbly strong frame and changeable mandrels, but the pins are as soft as cheese so bend at the least misalignment. I need to drill out the broken mandrel to accept a piece of hardened steel rod to preclude bending. Another job on the oops I forgot that again list. Link to comment Share on other sites More sharing options...
