PercyTheGreenEngine Posted December 10, 2012 Share Posted December 10, 2012 First post, and you can tell - this is ridiculously newbie question. I've just got TrackMaster up and running, but I can't work out how to rotate the track pieces. I can't even put two opposing sets of points together! Please help! Thanks Link to comment Share on other sites More sharing options...
Montywb Posted December 10, 2012 Share Posted December 10, 2012 You have to select the piece you want to rotate, ie click on it, and then use the left and right arrows to rotate it. Link to comment Share on other sites More sharing options...
PercyTheGreenEngine Posted December 12, 2012 Author Share Posted December 12, 2012 Montywb said: You have to select the piece you want to rotate, ie click on it, and then use the left and right arrows to rotate it. Link to comment Share on other sites More sharing options...
PercyTheGreenEngine Posted December 12, 2012 Author Share Posted December 12, 2012 Cheers. Found the manual swiftly after this and worked it from there. I have another not-so-newbie question to ask. How confident are people with the auto-lock function? Some of the configurations I've put together don't seem to quite link up, even though you would expect them to. Thanks Link to comment Share on other sites More sharing options...
96RAF Posted February 11, 2013 Share Posted February 11, 2013 I notice in the latest version you can click on a part and rotate it using the wheel on your mouse. Rob Link to comment Share on other sites More sharing options...
LMSTim Posted February 11, 2013 Share Posted February 11, 2013 You can also micro adjust pieces so that you can force them to go over another piece, or whatever. I think you use Shift and press the left or right arrows at the same time and move any item one pixel at a time. Link to comment Share on other sites More sharing options...
malang66 Posted February 11, 2013 Share Posted February 11, 2013 PercyTheGreenEngine said: Cheers. Found the manual swiftly after this and worked it from there. I have another not-so-newbie question to ask. How confident are people with the auto-lock function? Some of the configurations I've put together don't seem to quite link up, even though you would expect them to. I've also had this problem but whem i tryed it with track on my layout it linked up ok, I think trackmaster needs an overhale... thats why i got rid and pruchased full version of anyrail only thing is anyrail doesnt give you a price or parts list to print out.. Thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 11, 2013 Share Posted February 11, 2013 Anyrail does include a parts list. You'll find it under File tab then Info, and described on page 59 in the manual. Link to comment Share on other sites More sharing options...
