Captain_Francisco. Posted December 16, 2012 Share Posted December 16, 2012 I would like to make the programmimg track a siding off the main layout, as in the instructional video for the 'Elite' in the Hornby Website, and isolate it using a R618 isolating track controlled by a R 047 'on-off' switch. Could one then connect said controller to both the main layout track and the programmimg track, using the ports provided; programme a loco on the programming track, throw the switch, and then drive the newly programmed loco onto the circuit using the controller, or drive two locos onto the siding, isolate it, set them up as a double headed consist, then reset the switch, and drive the consist off back onto the main cicuit: no "hand of God removing and replacing. Are there any complications or is there a potential for damage in this setup that I am not seeing? Link to comment Share on other sites More sharing options...
poliss Posted December 16, 2012 Share Posted December 16, 2012 I would use a DPDT switch between the programming and normal running outputs of the controller. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 16, 2012 Share Posted December 16, 2012 I've done exactly that! A siding, the double pole double throw (DPDT) switch has the connectors in the centre of the six joined to the siding track, which is isolated from the rest of the layout. The programming output from the Elite goes to one side of the switch, and the 'running' output to the other. Just flip the switch, as appropriate. As I have a lot of DCC locos, I've added another isolating switch in the 'running' wires from the Elite to the rest of the layout, so when I'm programming a chip, I can be doubly sure I'm not resetting the whole lot by accident! Link to comment Share on other sites More sharing options...
Flashbang Posted December 16, 2012 Share Posted December 16, 2012 An R047 switch lever would not be able to provide double rail isolation switching! You would need two of them operated together to do this. Best is to use a DPDT centre and perhaps a Off type toggle switch. Typical programming track selection switch wiring is shown on this website if its of any help?.... http://www.brian-lambert.co.uk/DCC.htm#Programming%20Track Link to comment Share on other sites More sharing options...
Flashbang Posted December 16, 2012 Share Posted December 16, 2012 Oops! That second paragraph shoudl read as.... Best is to use a DPDT switch and perhaps a centre Off type toggle switch. Link to comment Share on other sites More sharing options...
Captain_Francisco. Posted December 16, 2012 Author Share Posted December 16, 2012 Thank you to both Poliss and 2e0dtoerric. Makes a lot of good sense. Glad to know you've already successfully done it, and particularly like the extra "insurance" isolating switch that you have incorporated. Thanks again. Link to comment Share on other sites More sharing options...
Captain_Francisco. Posted December 17, 2012 Author Share Posted December 17, 2012 Done & dusted. Works a treat. Thanks everyone. Link to comment Share on other sites More sharing options...
