Newfan Posted December 29, 2012 Share Posted December 29, 2012 I have just purchased a mixed freight set which was working fine until the controller started flashing 12 30 and the trains stopped working. On other forum I have worked this out to be one of the locks shorting the track. Does anyone have a suggestion of how I can fix this easily or what might be the cause. It was working fine then on the next switch on wasn't? Link to comment Share on other sites More sharing options...
poliss Posted December 29, 2012 Share Posted December 29, 2012 Do you get the error with no locos on the track? If so, then check for matal on the track, such as a track pin and also check the connections to the track and controller to see that a stray wires is not touching both terminals. Have you tried putting one loco at a time on the track to see which loco may be causing the problem? Link to comment Share on other sites More sharing options...
Willaov Posted December 29, 2012 Share Posted December 29, 2012 I have a problem like this but it only cuts out when I have points running. It even cuts out when just using the points with no track connected. Please help! Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 29, 2012 Share Posted December 29, 2012 Newfan, I'm assuming you've already done as suggested by poliss and tried each loco by itself and you get the short only when one of them is on the track and not the other. Assuming there is nothing obvious stuck there causing the short, I would take the set back to the shop, or at least the loco, for repair/replacement under warranty. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 29, 2012 Share Posted December 29, 2012 Willaov, can you give more detail? Do you mean it shorts out with just the track and no locos when you have installed the points in your layout? If so, try putting the points in one at a time to see if one particular point is causing it by having a short in it. Or if your layout has more than one power connection, are their polarities reversed? Or does it only happen when you have crossover points set to go from one loop to another? If so, do you have insulating rail joiners in the crossover? If not, you need them. If none of my suggestions apply, tell us more about how and when the short occurs. Link to comment Share on other sites More sharing options...
poliss Posted December 29, 2012 Share Posted December 29, 2012 Your problem is different Willaov. Sounds like you're overloading the system. Best to start your own thread for this or answers will get mixed up. Link to comment Share on other sites More sharing options...
Newfan Posted December 30, 2012 Author Share Posted December 30, 2012 Fishmanoz said: Newfan, I'm assuming you've already done as suggested by poliss and tried each loco by itself and you get the short only when one of them is on the track and not the other. Assuming there is nothing obvious stuck there causing the short, I would take the set back to the shop, or at least the loco, for repair/replacement under warranty. Link to comment Share on other sites More sharing options...
Newfan Posted December 30, 2012 Author Share Posted December 30, 2012 Thanks Fishmanoz and Poliss, have narrowed in down to one loco so will be taking the offending item back, it's a shame as the set is great apart from this issue. Link to comment Share on other sites More sharing options...
