St1ngr4y Posted December 31, 2012 Share Posted December 31, 2012 I have recently started to install One-touch DCC signals on my layout. I have found that 50% of them seem to be wired wrongly in that clear or stop messages sent to them have the opposite effect. That's no problem for Railmaster because there is a facility to 'reverse polarity' when configuring the signal on the layout. However, I discovered that occasionally these signals would not switch to 'stop' when under the control of a Railmaster program. I created this test program: 0 Program Command Repeat [10] times 2 Signal Controller A Port 104 Signal stop 4 Signal Controller A Port 104 Signal Clear 6 Program Command End Repeat While this program was running, the icon for signal 104 on the layout diagram switched between red and green every 2 seconds, but the signal itself remained constantly on green. By 'manually' switching the signal to red using the icon on the layout diagram, then obeying only the 'signal stop' command in the program, it appears that a signal clear is being sent instead of a signal stop, because the signal did change from red to green. Having said all that, I have found a way to cure the problem temporarily. As soon as I start up Railmaster, I go into the layout designer and load up the layout. Then I simply exit without making any changes or even re-saving it. Thereafter, all programs referencing those signals configured for reverse polarity, operate as they should. I have reported this through the help function built in to Railmaster and I'm waiting for a response. Link to comment Share on other sites More sharing options...
stevecamden Posted December 31, 2012 Share Posted December 31, 2012 Why don't you just swap the wires over on the decoder port? Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 31, 2012 Author Share Posted December 31, 2012 Hello Steve, Not that easy ... the decoder is built in to the base of the signal. The only two connections are those which connect to the track, rather like a Hornby connecting clip. Link to comment Share on other sites More sharing options...
Gregd99 Posted December 31, 2012 Share Posted December 31, 2012 if I understand you post correctly then 1. clicking on the icon always changes the icon colour 2. under programme control the icon colour changes but the actual signal does not 3. with manual clicking both the icon and the signal change colour is this right? if yes then the problem sounds like either the comms between railmaster and the elite or between the elite and the decoder. I have not observed an issues in the elite/decoder comms. I have observed many issues with the comms between the pc and the elite. It is possible you are experiencing the latter. if teh above is correct then I suggest that you raise with HCC. Link to comment Share on other sites More sharing options...
stevecamden Posted January 1, 2013 Share Posted January 1, 2013 Are you using the latest release of Railmaster 1.43. Its just that I tested this on my layout and had no problem. What I think is happening, perhaps, is that the 'reverse polarity' component in Railmaster isn't working with the signals when you run a script. If you get rid of the reverse polarities, I bet it works. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 1, 2013 Author Share Posted January 1, 2013 I have five of these One-Touch signals installed, three are two-aspect red/green, the other two are 4-aspect, R/Y/G/Y. The latter are handled by responding to two consecutive ports, so if you allocate address, say, 123 to the signal, then port 123 handles R/G, and port 124 handles the two yellows - stop = single yellow, clear = double yellow. The reverse polarity is present on the R/G port of both four-aspect signals, and on one of the two-aspect signals. The others, where I have not set the flag for reverse polarity, work fine every time. So, yes Steve, it is definitely an issue with the reverse polarity flag when the signal is controlled from a program. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 1, 2013 Author Share Posted January 1, 2013 Steve, I forgot to mention that I am using v1.43 of Railmaster. When you tried it out, did you set up a signal for reverse polarity? Link to comment Share on other sites More sharing options...
stevecamden Posted January 1, 2013 Share Posted January 1, 2013 Actually I have checked with the reverse polarity and I can confirm that the 'bug' is here when you run a script! Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 1, 2013 Author Share Posted January 1, 2013 Cheers Steve. I'll post whatever reply I get from HCC. Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 2, 2013 Author Share Posted January 2, 2013 Reply received from HCC: We have been looking into this issue and believe we have now resolved it. An update will be made available later today for automatic download (version 1.44) or you can download the update now and install it manually from www.powerpos.com/rail-master/rm_setup144.exe. Link to comment Share on other sites More sharing options...
stevecamden Posted January 2, 2013 Share Posted January 2, 2013 Goodness me - what else can we send you off to get resolved...... Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 2, 2013 Author Share Posted January 2, 2013 I've just tried out these signals on v1.44 and the bug has gone..... I still have one or two issues with HCC, still awaiting fixes, however... Link to comment Share on other sites More sharing options...
