PhilT Posted January 21, 2013 Share Posted January 21, 2013 I have just tried to update my elite from 1.3 to 1.4. The upload failed. I noticed the com port did not show elite so I updated the driver and got the message 3rd party INF does not contain digital signature. Now my elite is not working, only green lamp flashing on right side. Any ideas. Does anyone know how to get a digital signature upload for driver? Everyone told me not to go with Elite, so I hope this does not prove them right. I am using windows 8. No problems until now. Thanks Phil Link to comment Share on other sites More sharing options...
DaveAus Posted January 21, 2013 Share Posted January 21, 2013 Phil, I had issues with Windows 7 which I've resolved but I've not seen any instruction on doing the update via Windows 8. Hornby Customer Care https://www.hornby.com/contact-us/ might be a good starting point. Dave Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 21, 2013 Share Posted January 21, 2013 It is possible to get around W 8 requiring the. Digital signature as its default. Don't remember how myself but try googling it. I'm sure it's a setting somewhere in Control Panel. Apart from that the Upgrade procedure is exactly as for W 7. Getting HCC to tell you and everyone the answer is a good idea too, as would Hornby getting the signature. Link to comment Share on other sites More sharing options...
Gregd99 Posted January 21, 2013 Share Posted January 21, 2013 Phil, can you now see the com port under win8? if yes, then try the upgrade procedure again. My experience is that when the elite sits there looking like a brick it is still possible to load new fw into it. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 22, 2013 Share Posted January 22, 2013 Found the solution to running the driver under W 8: right click on the installation file, select Run in Compatibility Mode and select Previous Version. Now it should run for .you. Having installed, go to Device Manager and verify the port as per the Hornby update instructions and flow them meticulously, including disconnecting from track, disconnecting the power and doing the 15 seconds thing with the power connection. You should have no problem once the driver is in and you know which port. Link to comment Share on other sites More sharing options...
Mike_G Posted January 22, 2013 Share Posted January 22, 2013 Hi all I had the same problem myself last night trying to upgrade admittedly with win7 every thing whent ok till the end of the download stage when it got there it said download failure i tried several times, even though the com port setting were good and it showed the elite ok still no go elite was dead, sitting there with green light flashing lucky for me my main desktop is still runnin XP Pro run the update here and every thing whent ok first time elite now upgraded and working ok connected to my win7 laptop looking back through several posts this seems to be a problem with mostpeople with win7 / 8 not much help in this case for you, unless you can find someone with XP to help you out Rgds Mike Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 22, 2013 Share Posted January 22, 2013 Flow should be follow. Link to comment Share on other sites More sharing options...
PhilT Posted January 22, 2013 Author Share Posted January 22, 2013 Thanks everyone. Managed to overcome the W8 driver problem with help from hornby customer service. Now my problem is same as Mike G. Have contacted customer service again, but will try and get another PC with W7 to try and upgrade but will continue along with customer services until resolved. Its a shame I have this problem as unfortunately many of my club members did not recommend this route, ie Hornby and it appears they are having the last laugh. Never mind I will persever. Keep comment coming good to know others there to help. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 22, 2013 Share Posted January 22, 2013 This is not a W 7/8 problem, and it's not a 32/64 bit problem either. Plenty report having successfully upgraded on W 7 32 and 64 bit machines, and W 8 is only 7 with a fancy apps style front end. There are 2 causes for the problem as far as I can see: - it appears some hardware configurations can be difficult, although not impossible, and - some have difficulty getting the upgrade procedure right, even though the Hornby instructions do work if followed exactly. So do make sure for a start that you download the correct driver - it is different for XP and Vista/7/8 - do disconnect from track and power before you start and make sure you know which port the driver is on, and do press stop for 15 seconds before and after connecting the Elite to power and the USB connections as per instructions, and do run as Administrator (all as per the instructions) and if it doesn't work first time, try again. Mine worked second time. Good luck all. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 22, 2013 Share Posted January 22, 2013 And if you still have trouble and are in the UK, send back to Margate. Everyone who has done that reports success and good service. Look particularly for GordonBigBoy's post where he went to Margate and spoke to the person who did the upgrade for him while he waited. It's on this forum from around Christmas. Link to comment Share on other sites More sharing options...
Mike_G Posted January 23, 2013 Share Posted January 23, 2013 Well i did all those things and tried several times even cleaned every thing out the computer including the registry and tried again to no luck even tried adjusting the usb port settings, still no go like i said pluged into the Win WP Pro desktop it installed the drives and updated the elite first time no problems i did notice that the dowload time was slower on the XP machine maybe win 7/8 is running to quick for the elite ??? making it drop out at the end just a thought !!! anyway mines ok now so i am happy ( at the moment) Mike Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 23, 2013 Share Posted January 23, 2013 Well done Mike, glad you have been successful - another one to add to that list. But don't try to use this as evidence that W 7/8 don't work because they do. I did it with W 7 64 bit for a start. It is consistent with the different hardware/firmware configurations in the 2 machines you used, including your slower download time which is probably a combination of your Ethernet and/or wifi hardware, and the traffic volume at the time. Link to comment Share on other sites More sharing options...
PhilT Posted January 27, 2013 Author Share Posted January 27, 2013 Thanks all. After working with Customer services we found that W8 security has to be changed to allow not digital signature software to upload therebye correctly enabling the com port. It still kept failing to update the elite, but after borrowing an XP laptop it worked first time. Once again thanks to all. Link to comment Share on other sites More sharing options...
Gregd99 Posted January 27, 2013 Share Posted January 27, 2013 Phil, did HCC follow the Win8 story with you to the end? If they can understand any issues then they will be able to provide updated instructions. Link to comment Share on other sites More sharing options...
