Eamesey Posted February 3, 2013 Share Posted February 3, 2013 Hi I have a Sapphire decoder that I need to reset back to factory defaults any ideas, suggestions as to how I need to go about it. Thanks and Regards Link to comment Share on other sites More sharing options...
koo9 Posted February 3, 2013 Share Posted February 3, 2013 Set cv8 8 It is quicker to google. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 3, 2013 Share Posted February 3, 2013 Yes, you need to write 8 to CV 8. Follow the instructions in your controller on how to write CVs except, if it is a Select, it can't write CVs. Link to comment Share on other sites More sharing options...
Gregd99 Posted February 3, 2013 Share Posted February 3, 2013 Eamesey said: Hi I have a Sapphire decoder that I need to reset back to factory defaults any ideas, suggestions as to how I need to go about it. Thanks and Regards The advice about writing 8 to CV8 is all you can do for now. The decoder should NOT reset to defaults (eg address 3) unless there is some pretty catastrophic electrical event. a momentary short circuit should not do it; high electrostatic discharge might.... Keep an eye on the decoder and if the problem recurs then it might be worth contacting hornby. Link to comment Share on other sites More sharing options...
Flashbang Posted February 4, 2013 Share Posted February 4, 2013 Hi Gregd99 I don't think the OPs decoder has self reset? The OP was to be asking how do you reset it. Short circuits can occasionally reset decoders, as too can a poor DCC output data flow, especially at switch on and to a lesser extent at powering off. Much of this can be prevented by taking some external measures. If the OP has a Select and as previously stated, this cannot be used to reset a decoder, as it cannot write CVs other than the few its pre programmed to do. Link to comment Share on other sites More sharing options...
