DMU mad Posted February 6, 2013 Share Posted February 6, 2013 Hello all! I currently run a DCC layout using the Hornby Select, and I am looking into DCC sound. I read that the Select isn't capable of using the sound decoders to its full extent because it won't do "double functions", like F12 etc. Is this true? Will I be able to do functions between F1 and F16? Thanks Link to comment Share on other sites More sharing options...
rugbyboys Posted February 6, 2013 Share Posted February 6, 2013 The Select will carry out functions up to F9 but saying that I used my select for a couple of years running DCC sound and it worked fine not that many functions above that number but dont let this put you off getting a DCC sound Loco because it really is a different level, hope that this helps. Link to comment Share on other sites More sharing options...
DMU mad Posted February 6, 2013 Author Share Posted February 6, 2013 So just to confirm, you can go up to F9, but not F10, 11, 12, etc..... However, the sounds after that aren't really important. Is that what you're saying? I'm a little confused. Link to comment Share on other sites More sharing options...
Gregd99 Posted February 7, 2013 Share Posted February 7, 2013 I think that he is saying not that many functions above F9 are used to generate sounds. I don;t know if this is correct or not but if I payed a lot of money for a sound loco then i would want to be able to control every sound!! The select also has very limited CV programming capability. this means that you will not be ale to tune sound volumes or.... in my opinion the sound locos are rolls royce locos. the select is a mini minor controller. It is fin if you only want a min but with the rolls you need an elite. Link to comment Share on other sites More sharing options...
The son of Triangman Posted February 7, 2013 Share Posted February 7, 2013 The Select is limiting in what it can do, it's an introduction to DCC controller really, ideal for those starting out. Upgrade to an Elite or similar as soon as you can if you want more from DCC. Link to comment Share on other sites More sharing options...
rugbyboys Posted February 7, 2013 Share Posted February 7, 2013 Hi thats exactly what I am saying the Select will carry out functions up to F9 but that covers most of the basic important sounds after that it is things like guards whistle or rail clatter or even seagull sounds, It covers the main basic sounds what you would need. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted February 7, 2013 Share Posted February 7, 2013 If this works - I made a quick compilation of what sound function did what, across the two main players. -------------------- DCC Functions Steam Diesel 00 00 directional lights 01 Sound on/off 01 sound on/off 02 Steam whistle long 02 Horn 03 coupling clank 03 coupling clank 04 Steam signalling whistle 04 compressor 05 injector 05 brake release 06 shunting mode 06 shunting mode 07 shovelling coal 07 short horn 08 cylinder blow-through 08 diesel notch-up 09 safety valve 10 flange squeal 11 rail clank 12 blower or 00 00 Direction lights 01 sound on/off 01 sound on/off 02Whistle long 02 single horn 03 coupling clank 03 double horn 04 injector 04 fans 05 shunting mode speeds 05 notch up 06 coal shovelling 06 notch down 07 blower 07 shunting speed on/off 08 short whistle 08 cab lights 09 buffer clank 10 coupling noise Link to comment Share on other sites More sharing options...
2e0dtoeric Posted February 7, 2013 Share Posted February 7, 2013 Well - it half worked, it has crunched them all up. Link to comment Share on other sites More sharing options...
