modelman Posted February 9, 2013 Share Posted February 9, 2013 Can somebody help me out. I've got a 10ft by 5ft layout being built up with two tracks that split into four running lines and back again. I have wired the layout using the express models DCC non solder power bus kit with PECO code 100 streamline points and track with points that are large radius insulated frog points. I pluged it all in with special chocbloc connectors on each board/section and when I plug the controller in the whole thing shortens out. I took the wiring apart and ensured nothing metal is on the rails and all wires are soldered properly but I just don't know what's wrong. Can somebody give me some suggestions or advice please? I've been whacking my brains out for the last few weeks and have gotten no-where! Link to comment Share on other sites More sharing options...
brando Posted February 9, 2013 Share Posted February 9, 2013 Hi, have you fitted the DCC point clips to all your points ? Link to comment Share on other sites More sharing options...
poliss Posted February 9, 2013 Share Posted February 9, 2013 You have no live frog points at all? Are the wires colour coded? If you put a piece of coloured tape, the same colour as the wire, on the side of a wagon you can run it round the track by hand to see if the wires get mixed up. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 10, 2013 Share Posted February 10, 2013 I agree with poliss that you are looking for a probable polarity reversal with one or more of your bus connections. To prove this, disconnect the bus connectors one by one until the short disappears. The last one disconnected will be your reversed connection. Correct this then reconnect one by one and the short may recur if you have more then one reversals. Keep correcting reversals until you have all bus connections remade and no short. If this doesn't work, the likelihood is that your layout has a reversing loop. Is it possible that you can run a train in one direction from a point in the layout and have it arrive back at this point from the other direction? If so, that is a reversing loop and you will have to isolate it and use a reversing loop module. Link to comment Share on other sites More sharing options...
Flashbang Posted February 10, 2013 Share Posted February 10, 2013 Hi I agree with Poliss, you have got one or more dropper wires crossed over somewhere. As suggested by Poliss the simplest testing method is to take a four wheeled wagon and along one long side place a piece of tape - PVC insulating tape, masking tape or even a small band aid plaster, it really doesn't matter so long as it wont fall off. Now place the wagon onto the track so as the taped side is directly above a rail that has the red dropper wire (I say Red but the colour used is up to you so long as different colours are used for the two rails!). The taped side of the wagon now indicating the rail directly below it that has the red dropper wire which goes to the red bus wire below - Visually check that is correct. Obviously the opposite side rail has the other coloured dropper wire (say Black) connected to it. Now the most important thing is not to remove the wagon during any of the checks. So by finger push the wagon around the track, every time you reach a dropper wire the taped side of the wagon and its rail directly under it must have the red dropper wire connected. Move into sidings and loop to loop by using the points - Don't lift the wagon off the rails to move anywhere. Obviously all the red droppers must connect to the red coloured bus wire and all black coloured droppers to the black bus wire. When you have finished and you're sure every dropper has been checked and if necessary corrected, remove the wagon and take off the piece of tape. Now your rails are all connected correctly to the bus and no short should be found. If there is a short then you need to investigate further - Remove all locos and rolling stock and retest, if short is still present then look something metal bridging across the rails. Or the use of an Electrofrog point that hasn't had two Insulated Rail Joiners (IRJs) fitted to its Vee rails. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted February 10, 2013 Share Posted February 10, 2013 Reading the opening words - - I've got a 10ft by 5ft layout being built up with two tracks that split into four running lines and back again. This sounds like an out and back layout, not a tailchaser. In which case, our writer needs a reversing module, and insulating breaks in the loop. Link to comment Share on other sites More sharing options...
modelman Posted February 10, 2013 Author Share Posted February 10, 2013 It's not an out and back layout as it's still being built. I will have six storage loops at the back end. I have used DCC clips and gone through the connections and still have errors popping up. Link to comment Share on other sites More sharing options...
DaveAus Posted February 10, 2013 Share Posted February 10, 2013 When I was putting my track together mine was caused by a faulty point that was shorting out on the turn. Link to comment Share on other sites More sharing options...
modelman Posted February 10, 2013 Author Share Posted February 10, 2013 Well I guess that could be the problem as I've got one point that is slightly faulty. and with only two connections made before the express points I have power on one set of rails and not the other. I'll look at this and maybe replace the faulty point. Thanks for the advice. I'll let you know how I get on. Link to comment Share on other sites More sharing options...
