malang66 Posted February 15, 2013 Share Posted February 15, 2013 Hi all im running a small layout and im going to go dcc.. bought a select as only what to run about 3 to 4 locos at any one time which chips would be better for me to use... Link to comment Share on other sites More sharing options...
Rog RJ Posted February 15, 2013 Share Posted February 15, 2013 The basic Hornby R8249 is what I'd recommend as the Select can't alter the CV settings of other decoders to get the best out of them. Link to comment Share on other sites More sharing options...
malang66 Posted February 15, 2013 Author Share Posted February 15, 2013 Rog (RJ) said: The basic Hornby R8249 is what I'd recommend as the Select can't alter the CV settings of other decoders to get the best out of them. cheers Rog... i get a couple to try out in the club loco and another 0-4-0 i have at mo as only just getting started after many years of owning a oo gauge layout... Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 15, 2013 Share Posted February 15, 2013 Just a heads up for when you go to install a chip in your 0-4-0 - the Hornby instructions on this site a quite lengthy because they assume the motor is mounted with its connections facing down when in fact later 0-4-0s have them facing up. If so, there is no need to remove the motor, just rearrange the connections to go via the the chip (decoder red and black to pickups and decoder orange and grey to the motor). I've previously posted a full set of the necessary steps so do a search for them on here. Link to comment Share on other sites More sharing options...
Gregd99 Posted February 15, 2013 Share Posted February 15, 2013 I had a problem when I removed a motor from an 0-4-0. After replacing something was not quite right and the worm drive would slip:-( Added to that I used an 8215 :-( decoder which was not a very good idea. Link to comment Share on other sites More sharing options...
Gregd99 Posted February 15, 2013 Share Posted February 15, 2013 which chip? have a look at https://www.hornby.com/forums/hornby-forums/hornby-digital/4399/ Link to comment Share on other sites More sharing options...
