steamfreak Posted March 4, 2013 Share Posted March 4, 2013 Hi all As well as other functions I have a smoke unit on one of my locos.This set up as F16 , it works fine when using the Elite on it's own but will not work with the function control on Railmaster although all other functions do. any ideas please? steamfreak Link to comment Share on other sites More sharing options...
St1ngr4y Posted March 4, 2013 Share Posted March 4, 2013 Have you set up F16 for this loco in the locomotives list? If so, what description did you choose for it? Ray Link to comment Share on other sites More sharing options...
stevecamden Posted March 4, 2013 Share Posted March 4, 2013 Perhaps it has to be defined as a latching function in Railmaster F16 ' Smoke Unit on/off' Link to comment Share on other sites More sharing options...
St1ngr4y Posted March 4, 2013 Share Posted March 4, 2013 Steve, How do you define a 'new' latching function? Is it simply by including on/off at the end of the description? Ray Link to comment Share on other sites More sharing options...
steamfreak Posted March 4, 2013 Author Share Posted March 4, 2013 Hi St1ngr4y/stevecamden I simply called it Smoke,I assumed that by using the railmaster buttons it would just switch on or off like any other function regards steamfreak Link to comment Share on other sites More sharing options...
LMSTim Posted March 4, 2013 Share Posted March 4, 2013 Any function which, when turned on stays on until it is turned off, is a latching function and therefore must have "on/off" somewhere in the descrition. "Smoke on/off" would do the trick. Link to comment Share on other sites More sharing options...
steamfreak Posted March 4, 2013 Author Share Posted March 4, 2013 Thanks to all for your help I will try again tomorrow and report back thanks once again steamfreak Link to comment Share on other sites More sharing options...
St1ngr4y Posted March 4, 2013 Share Posted March 4, 2013 I've just been experimenting on an evaluation copy which isn't connected to an Elite or anything. I created F16 for a loco with description 'Smoke on/off', and when used on the main screen, it's background colour changed to green, as if it had been toggled 'on', then another click changed it's colour back to grey. I then changed the description to simply 'Smoke'. On the main screen, the colour wouldn't change to green. So it looks as if this configuration could be making it a momentary function, rather than a latching function. So try adding ' on/off' to the description to see if it makes a difference. Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted March 4, 2013 Share Posted March 4, 2013 LMSTim said: Any function which, when turned on stays on until it is turned off, is a latching function and therefore must have "on/off" somewhere in the descrition. "Smoke on/off" would do the trick. Sorry LMSTim, I posted my last message before I saw yours. Is this documented in the Railmaster manual? Link to comment Share on other sites More sharing options...
steamfreak Posted March 5, 2013 Author Share Posted March 5, 2013 St1ngr4y said: LMSTim said: Any function which, when turned on stays on until it is turned off, is a latching function and therefore must have "on/off" somewhere in the descrition. "Smoke on/off" would do the trick. Sorry LMSTim, I posted my last message before I saw yours. Is this documented in the Railmaster manual? Link to comment Share on other sites More sharing options...
steamfreak Posted March 5, 2013 Author Share Posted March 5, 2013 Hi guys excellent advice smoke unit now works fine via Railmaster thanks for the help steamfreak Link to comment Share on other sites More sharing options...
