Shadow.Monk Posted May 10, 2013 Share Posted May 10, 2013 Hi all, Can anyone suggest alternate couplings to narrow the gap between engines and rolling stock? As I am wanting to make my trains look as realistic as I can and the default couplings that come with the stock are good to start off with, but I am looking to move away from that now. Cheers Link to comment Share on other sites More sharing options...
Alessio Posted May 11, 2013 Share Posted May 11, 2013 I'm afraid I can't recommend a product but I know they do exist. It may be worth having a look at Model Rail/Hornby Magazine and such like in your local newsagent- they often mention these things. Sorry I can't be of any further help. Link to comment Share on other sites More sharing options...
81F Posted May 11, 2013 Share Posted May 11, 2013 The close couplings supplied with some of the new Hornby Coaches do narrow the gap between the Coaches so these could be used on other stock and locos providing they are fitted with nem pockets. I use them on a couple of fixed rakes - a train of 6 wheeled milk tanks and some grain hopper wagons and they do make a bit of a difference. They also eliminate the opening and closing between stock which is good for coaches but not for loose coupled coal trains. I once had a chat with a volunteer at Pendon Museum and they use something as simple a length of stiff wire fixed to one end of a coach which hooks into a hole in the floor of the nect coach and bent to look like the vacuum brake pipes. However, their coaches are in permanent rakes so each is made to suit to couple two specific coaches - not very flexible. For goods rolling stock the most realistic is three link, which I did try in my 20s but it is very fiddly and you really need large radius curves if you are going to push the rolling stock to avoid buffer lock. This and the fiddliness can make shunting a bid tedious. Link to comment Share on other sites More sharing options...
dude2112 Posted May 11, 2013 Share Posted May 11, 2013 It depends how old your rolling stock and engines/tenders are. I have lots of newish coaches that have close couplings but still use the old coupler to the tender/engine as its less troublesome..... Hope this helps Link to comment Share on other sites More sharing options...
LCDR Posted May 13, 2013 Share Posted May 13, 2013 There is a commercially available system that allows coaches to be close coupled on straight track but opens up on curves to avoid buffer locking, much as Hornby's super detailed carriages do. It does require some modification to the vehicle, which requires some modelling skill. The proprietor is very keen for people to use his system. He advertises in the Railway Modelling press. He also supplies scale bogies for Pullmans. Link to comment Share on other sites More sharing options...
