Doudar Posted June 15, 2013 Share Posted June 15, 2013 I have a small analogue layout which I am about to expand and start changing to digit. I would like to get the Hornby Select DC first but was wondering if this would still control my older trains as well as any new digital ones I purchased. Thanks John Link to comment Share on other sites More sharing options...
walkingthedog Posted June 15, 2013 Share Posted June 15, 2013 You cannot run analogue (DC) locos on a digital (DCC) layout but you can run DCC on a DC layout. You would have to convert your DC locos to DCC. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted June 15, 2013 Share Posted June 15, 2013 Also, the Select controller is very limited, not only in functions, but also the decoders that will work with it. I would suggest you go straight to the Elite unit, which although more expensive, will indirectly save you a lot of money, as you will end up buying one anyway! Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 15, 2013 Share Posted June 15, 2013 I agree with Eric that you should go for the Elite, not the Select. Take a look at my post at the bottom of the page at https://www.hornby.com/forums/hornby-forums/hornby-digital/4463/ to see the benefits of the Elite over the Select. As you are just starting out, you may think a number of things I've listed are very advanced but, once you get into DCC, you'll find you want to do many of those things. Link to comment Share on other sites More sharing options...
Doudar Posted June 16, 2013 Author Share Posted June 16, 2013 Thanks for the advice gents, think I will hold back for a while until I can afford the Elite or maybe go for Train master with the eLink option. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted June 19, 2013 Share Posted June 19, 2013 You're already thinking ahead and going big... I haven't looked at Fishy's post but no doubt it tells you that the Elite can be manipulated in so many ways to enable what you require whereas the Select is just a box of minor tricks for the smallest layout with no real special add-ons required. (No offense to those running the Select but hopefully you get what I mean :-) ). Link to comment Share on other sites More sharing options...
The son of Triangman Posted June 19, 2013 Share Posted June 19, 2013 Forget the Select it's too limiting and is non NMRA compliant so there are compatibility issues. As your layout progresses, you will need the Elite. Link to comment Share on other sites More sharing options...
