gilbo2 Posted July 15, 2013 Share Posted July 15, 2013 I use the Elite Loco address 0000 for controlling non DCC trains, but I find the motors get quite warm/hot. Could I temporarily swap the Elite for an old Analogue controller for train testing purposes without damaging the R8247 Accessory Decoders which would then be fed off my Bus with 0-12VDC? I don’t want to damage the accessory decoders, realising that they will not work under this temporary setup! Link to comment Share on other sites More sharing options...
Graskie Posted July 15, 2013 Share Posted July 15, 2013 Best not to run analogue locos on the Elite using the address 00 for more than a very short while anyway. You say the motors warm up, and you can in fact damage them that way. I only use that setting to briefly test any non-DCC locos I'm getting rid of, just to make sure they do actually run. With regard to swapping to a DC controller to run these locos, there could, of course, be problems with isolated sections of track compared to using your Elite. I don't know for sure what the effect could be on your accessory decoders but I personally would not risk trying it. Perhaps someone with more electrical knowledge than mine could elaborate on that aspect of your query. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 15, 2013 Share Posted July 15, 2013 Agree with Graskie, it is possible to burn out your armature windings running DC locos on DCC. In fact, it is recommended you turn DC mode off as it can also stop loco full speed runaways where they may inadvertently interpret a DCC signal as DC with full volts. Also not sure about damage to accessory decoders on DC. I have a separate small loop to test DC locos. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 15, 2013 Share Posted July 15, 2013 Damage is most likely when you leave a DC loco sitting stationary on a DCC track. Link to comment Share on other sites More sharing options...
Brightonrock Posted July 16, 2013 Share Posted July 16, 2013 Yes the non-DCC locos sit and hum all the time they are on the track..shame but mine are concined to the box and replaced Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 16, 2013 Share Posted July 16, 2013 Wy don't you fit decoders to them BR? Link to comment Share on other sites More sharing options...
gilbo2 Posted August 23, 2013 Author Share Posted August 23, 2013 Thanks for all the feedback. Have now fitted the DCC decoders to avoid any possible problems :-) Link to comment Share on other sites More sharing options...
