Derrick_W_Martin Posted July 18, 2013 Share Posted July 18, 2013 Can anyone tell me why the new e-link system only has a 1 amp power supply? I model in "n" gauge and I would like to know how many trains and accessories can I run with this unit? If I buy the Hornby power booster unit how do I connect it to the e-link? Has anyone else got these problems? Link to comment Share on other sites More sharing options...
Gregd99 Posted July 19, 2013 Share Posted July 19, 2013 I could not see it stated on the web site but as I the e-link is also compatible with the 4A transformer. see https://www.hornby.com/shop/digital/p9300-digital-15v-4-amp-transformer/ That would be the most cost effective way to increase the puff available to the track. A booster as you mention (https://www.hornby.com/shop/power-and-control/r8239-hornby-dcc-power-and-signal-booster/) is more expensive and has a relay function built in for the DCC signals. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 20, 2013 Share Posted July 20, 2013 Clearly they used the 1Amp supply to keep the entry price down, just as they did with Select. It is still much cheaper to buy eLink plus the 4Amp than it is to buy Elite. And that is all you need to do. For most, buying a booster will be overkill. Link to comment Share on other sites More sharing options...
