francisk Posted July 29, 2013 Share Posted July 29, 2013 Hi, Can anyone tell me can I use my LENZ 5 amp transformer to power the elink, it seems a shame to have to buy anothe Francisk Link to comment Share on other sites More sharing options...
poliss Posted July 29, 2013 Share Posted July 29, 2013 You could try contacting the Hornby technical department giving full details of your power supply. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 29, 2013 Share Posted July 29, 2013 I agree with poliss. To have any chance of it working, the voltage supplied by the Lenz will have to be the same as supplied by the eLink 1Amp, and you should find that moulded into the cases of the 2 supplies. Then the connector will have to be the same. Even if all of that is the case, Hornby will almost certainly tell you that you will void your warranty by not using one of the Hornby supplies. Link to comment Share on other sites More sharing options...
