gilbo2 Posted August 3, 2013 Share Posted August 3, 2013 I have a pair of points wired to different ports. Is it possible to make RailMaster change them at the same time, I can only enter one address at a time? Link to comment Share on other sites More sharing options...
Rog RJ Posted August 3, 2013 Share Posted August 3, 2013 Just connect both points to the same port Link to comment Share on other sites More sharing options...
gilbo2 Posted August 3, 2013 Author Share Posted August 3, 2013 Rog (RJ) said: Just connect both points to the same port Yes, I was trying to avoid that to give the cdu a fighting chance :-) Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 3, 2013 Share Posted August 3, 2013 It is well established that the decoder is capable of firing 2 Hornby point motors at once. So there should be no CDU problem. Link to comment Share on other sites More sharing options...
gilbo2 Posted August 4, 2013 Author Share Posted August 4, 2013 Thanks for the replies. It's a shame railmaster does not do it but I note the rewiring option. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 4, 2013 Share Posted August 4, 2013 If you really want to do it separately, write yourself a short program in RM to do it and you can change them at the points pause interval between. But if you keep using separate ports for points that always change at the same time, you are going to have to buy more accessory decoders then you really need. And note the RM manual tells you how to go about this under points setting, not that it difficult to set up 2 points with the same decoder address. Link to comment Share on other sites More sharing options...
