Deltic_Malc Posted August 19, 2013 Share Posted August 19, 2013 Hi, I have railmaster and an elink. The problem I'm having is that one set of points will not operate in a program. The points operate fine when I "click" with the mouse but when they are put in command line of a program they do not operate. The line runs no the status bar but nothing physically happens. They were working fine in the program but have stopped working. As I say they work fine with the mouse, so all the addressing etc is fine, I have left 5 seconds in between this command and the commands at either side of it. The points operate fine when recording a program, Its just they do not when I run the program. Any ideas? I have not change any settings on my computer or added removed any hardware or software. All the other points operate ok in the program. Thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 19, 2013 Share Posted August 19, 2013 So Mal, when you say it doesn't work, does it seem as if it is trying to work but fails, or completely dead with no sound or any movement whatsoever? Have you tried putting the instruction in the program twice to see if that makes a difference? And it's good to hear from an new eLink user who seems to have been able to get set up and running, albeit with this curious problem, unlike some others here. But then the forum only hears from those who have problems usually. If you can be bothered, can you tell us how it went out of the box please. For a start, what Windows version are you using, then, any trouble installing the eLink driver and finding its com port, any trouble installing the program as administrator, any problem with the auto update of the program and eLink firmware on first running, and finally, any subsequent handshake problems? Link to comment Share on other sites More sharing options...
Deltic_Malc Posted August 20, 2013 Author Share Posted August 20, 2013 Fishmanoz said: So Mal, when you say it doesn't work, does it seem as if it is trying to work but fails, or completely dead with no sound or any movement whatsoever? Have you tried putting the instruction in the program twice to see if that makes a difference? And it's good to hear from an new eLink user who seems to have been able to get set up and running, albeit with this curious problem, unlike some others here. But then the forum only hears from those who have problems usually. If you can be bothered, can you tell us how it went out of the box please. For a start, what Windows version are you using, then, any trouble installing the eLink driver and finding its com port, any trouble installing the program as administrator, any problem with the auto update of the program and eLink firmware on first running, and finally, any subsequent handshake problems? Link to comment Share on other sites More sharing options...
Deltic_Malc Posted August 20, 2013 Author Share Posted August 20, 2013 Thanks for answering, it doesn't even try, no sound at all and yes I've tried putting the instruction twice with 2, 3and 5 second gaps, as I said it did work in the program and works fine when I use the mouse. I have had the e link for about a month now, I have quite a large layout about 20ft x 15ft in the loft. It's mainly three loops with inter connections on two levels with two stations a turntable and 24 sets of points. 12 of which are controlled by the e-link via DCC Concepts and Lenz accessory decodes. I have 25 locos, a combination of sound and non-sound with a variety of hornby, Bachman and trainserve decodes. I have only ran four locos on the e-link at the moment. Well that's a bit about my system. I am using a to shiva satellite laptop about 8 years old clock speed 1.3 and 2gb of ram, with windows XP, operating system. On vergin broadband with their security software / firewall. I have tried to have no other program's running while running railmaster. So out of the box. Installed as per the instructions and no problems, software installed ok, registered fine conned etched e-link ok. Checked com port via system settings on XP and put this into railmaster. All worked fine. Have updated ok and on version1 1.52 all done automaticly. I have had a lot of handshake notifications and lots of other niggles. Not finding controller etc, usually due to XP putting e-link on a different com port, as its virtual, there must be way to stop this. Handshake I put down to , as most of the problems seem to be, the speed XP reacts to the commands (slowly sometimes) as its doing other things, it is an operating system for the pc not just railmaster. Generally a good product but a few teething problems. Link to comment Share on other sites More sharing options...
RB51 Posted August 20, 2013 Share Posted August 20, 2013 Deltic_Malc said: Thanks for answering, it doesn't even try, no sound at all and yes I've tried putting the instruction twice with 2, 3and 5 second gaps, as I said it did work in the program and works fine when I use the mouse. I have had the e link for about a month now, I have quite a large layout about 20ft x 15ft in the loft. It's mainly three loops with inter connections on two levels with two stations a turntable and 24 sets of points. 12 of which are controlled by the e-link via DCC Concepts and Lenz accessory decodes. I have 25 locos, a combination of sound and non-sound with a variety of hornby, Bachman and trainserve decodes. I have only ran four locos on the e-link at the moment. Well that's a bit about my system. I am using a to shiva satellite laptop about 8 years old clock speed 1.3 and 2gb of ram, with windows XP, operating system. On vergin broadband with their security software / firewall. I have tried to have no other program's running while running railmaster. So out of the box. Installed as per the instructions and no problems, software installed ok, registered fine conned etched e-link ok. Checked com port via system settings on XP and put this into railmaster. All worked fine. Have updated ok and on version1 1.52 all done automaticly. I have had a lot of handshake notifications and lots of other niggles. Not finding controller etc, usually due to XP putting e-link on a different com port, as its virtual, there must be way to stop this. Handshake I put down to , as most of the problems seem to be, the speed XP reacts to the commands (slowly sometimes) as its doing other things, it is an operating system for the pc not just railmaster. Generally a good product but a few teething problems. Link to comment Share on other sites More sharing options...
RB51 Posted August 20, 2013 Share Posted August 20, 2013 In relation to e-link I am running this on a W8 laptop, which I purchased for this purpose (Dell Inspiron 15 - a bit extravagant but they had an offer on!) as it had touch screen. The only other program on there is SCARM and I have my loco (12) cleaning/running schedule which is a small Excel document. I have a much smaller layout - 6.5ft x 4ft which consists of two running loops 12 points and a double slip. My experience of e-link "out of the box" was the same as his and I have the same issues as Deltic which personally I don't think is horrendous given the newness of the product. I also occasionally get a blank screen on start-up leaving only the "connecting to e-link" dialogue. It lasts only a few seconds and does not seem to effect anything. I don't understand the finer elements of how PC's (or e-link for that matter) work, but I am very grateful for the input of those who do. I just want to "play trains" and the e-link is brilliant for folk like me. And of course, you cant beat the price! At risk of sounding sycophantic I have to say (as many others here have) that the support Hornby give if you need to contact them is first class. Always timely, patient and they keep it simple. Hope that helps anyone trying to make a choice. R- Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 20, 2013 Share Posted August 20, 2013 Deltic_Malc said: Hi, I have railmaster and an elink. The problem I'm having is that one set of points will not operate in a program. The points operate fine when I "click" with the mouse but when they are put in command line of a program they do not operate. The line runs no the status bar but nothing physically happens. They were working fine in the program but have stopped working. As I say they work fine with the mouse, so all the addressing etc is fine, I have left 5 seconds in between this command and the commands at either side of it. The points operate fine when recording a program, Its just they do not when I run the program. Any ideas? I have not change any settings on my computer or added removed any hardware or software. All the other points operate ok in the program. Thanks Hi What is the address of the points decoder port? Have you tried running the program in the program editing window? You can flag only that line for execution, rather than run the whole program. Ray Link to comment Share on other sites More sharing options...
Deltic_Malc Posted August 20, 2013 Author Share Posted August 20, 2013 St1ngr4y said: Deltic_Malc said: Hi, I have railmaster and an elink. The problem I'm having is that one set of points will not operate in a program. The points operate fine when I "click" with the mouse but when they are put in command line of a program they do not operate. The line runs no the status bar but nothing physically happens. They were working fine in the program but have stopped working. As I say they work fine with the mouse, so all the addressing etc is fine, I have left 5 seconds in between this command and the commands at either side of it. The points operate fine when recording a program, Its just they do not when I run the program. Any ideas? I have not change any settings on my computer or added removed any hardware or software. All the other points operate ok in the program. Thanks Hi What is the address of the points decoder port? Have you tried running the program in the program editing window? You can flag only that line for execution, rather than run the whole program. Ray The address of the decoder is 6, tried what you suggest and also in a program on its own but still will not operate. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 20, 2013 Share Posted August 20, 2013 You have me stumped. Suggest you try RM Support. Link to comment Share on other sites More sharing options...
Graskie Posted August 20, 2013 Share Posted August 20, 2013 We had lots of your sportsmen stumped recently, didn't we, Fishy? Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 20, 2013 Share Posted August 20, 2013 It was more caught, or not. Link to comment Share on other sites More sharing options...
Graskie Posted August 20, 2013 Share Posted August 20, 2013 Stumped by being caught then. Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 21, 2013 Share Posted August 21, 2013 Deltic_Malc said: St1ngr4y said: Deltic_Malc said: Hi, I have railmaster and an elink. The problem I'm having is that one set of points will not operate in a program. The points operate fine when I "click" with the mouse but when they are put in command line of a program they do not operate. The line runs no the status bar but nothing physically happens. They were working fine in the program but have stopped working. As I say they work fine with the mouse, so all the addressing etc is fine, I have left 5 seconds in between this command and the commands at either side of it. The points operate fine when recording a program, Its just they do not when I run the program. Any ideas? I have not change any settings on my computer or added removed any hardware or software. All the other points operate ok in the program. Thanks Hi What is the address of the points decoder port? Have you tried running the program in the program editing window? You can flag only that line for execution, rather than run the whole program. Ray The address of the decoder is 6, tried what you suggest and also in a program on its own but still will not operate. The only thing I can suggest is to go into the track layout editor and delete both the point and its green/red buttons. Then re-insert the point and its buttons, and re-configure its address etc. Then save the layout, and re-edit your program. Go to the offending line and use the drop-down list to set it to address 6 (even if it is already showing this address). If this doesn't work, then I, too, am stumped. Ray Link to comment Share on other sites More sharing options...
Deltic_Malc Posted August 26, 2013 Author Share Posted August 26, 2013 Thank you to everyone for their advice, finally found the problem. New Glasses on, head under the baseboard and found a wiring fault, entirely my own cause. Hopefully the thread helped other members as well :-) Link to comment Share on other sites More sharing options...
