rob50 Posted September 30, 2013 Share Posted September 30, 2013 Just got one of these. And can't get lights to work in any direction.have tried resetting my select controller. And have tried different loco addresses. Still same prob. Any help would be great. Thx rob Link to comment Share on other sites More sharing options...
idlemarvel Posted October 1, 2013 Share Posted October 1, 2013 rob50 said: Just got one of these. And can't get lights to work in any direction. Usually if loco moves but lights don't work it means the decoder is in the wrong way round. I have one of these (Alstom model). If you want directional lights to work in the end car that needs a decoder as well. Link to comment Share on other sites More sharing options...
Bexhill Donkey Posted October 8, 2013 Share Posted October 8, 2013 You have to write the value of 8 to CV 8 to reset the decoders. Link to comment Share on other sites More sharing options...
beejack Posted October 10, 2013 Share Posted October 10, 2013 Bexhill Donkey said: You have to write the value of 8 to CV 8 to reset the decoders. You can't write cv8 on the select so this won't work! As mentioned above if you installed the chip yourself then you probably plugged it in the wrong way round. If it is DCC fitted then return it to where you bought it from for a fix. Link to comment Share on other sites More sharing options...
