xenon1000 Posted August 3, 2011 Share Posted August 3, 2011 hi alli have converted my turntable to dcc, but i'm haveing problems with railmaster controlling it.if i controll it useing the elite its works ok, but have to put the throttle to max, but if i use railmaster it moves a small amount then stops, but the is still power going to it untill railmaster thinks its got to the position i have asked for, then the power turns off.can i ajust the turntables peramitors in railmaster so it instructs the decoder to give full power???or is there something else i can do to make it work???really need some help guys??? Link to comment Share on other sites More sharing options...
LMSTim Posted August 4, 2011 Share Posted August 4, 2011 You can change both the speed and time it takes to move from one road to another in the railmaster.ini file settings in the Railmaster folder. This is all explained in the manual. You will see entries called:-Turntable speed=40 This is the power setting being sent to the DCC chipTurntable timer=23.56 This is the precise number of seconds to move one roadIf you are going to change the above settings be prepared for a long period of trial-and-error to get the number of seconds (to the one hundredth as you can see) just right.Having said that, you shouldn't need to change those settings, unless perhaps you have a dodgy turntable with old motor/gearing.You definitely DON'T want to be running the turntable at full power because A) it's very, very noisy, B) it's not to scale C) it looks daft going around so fast - nothing like the real thing.Because RailMaster handles the starting and stopping of the turntable you don't need to worry that'll it take around 20 seconds to move from one road to the other. Just press the button and forget about it. Link to comment Share on other sites More sharing options...
xenon1000 Posted August 4, 2011 Author Share Posted August 4, 2011 LMSTim said:You can change both the speed and time it takes to move from one road to another in the railmaster.ini file settings in the Railmaster folder. This is all explained in the manual. You will see entries called:-Turntable speed=40 This is the power setting being sent to the DCC chipTurntable timer=23.56 This is the precise number of seconds to move one roadIf you are going to change the above settings be prepared for a long period of trial-and-error to get the number of seconds (to the one hundredth as you can see) just right.Having said that, you shouldn't need to change those settings, unless perhaps you have a dodgy turntable with old motor/gearing.You definitely DON'T want to be running the turntable at full power because A) it's very, very noisy, B) it's not to scale C) it looks daft going around so fast - nothing like the real thing.Because RailMaster handles the starting and stopping of the turntable you don't need to worry that'll it take around 20 seconds to move from one road to the other. Just press the button and forget about it.Thank you for your reply, it was very helpfullwhere in the manul does it state about the ini file, i'm asking as i did not see that info.anyway i have sorted the problem,the gears are fine in the turntable, but i found a bad solder joint on the motor, once i sorted this all worked fine.i did not want to make it move fast i just wanted it to work, and now it does.thanks again. Link to comment Share on other sites More sharing options...
LMSTim Posted August 4, 2011 Share Posted August 4, 2011 It's on pages 38 and 39 about the tipper and conveyor but when you look at the file all of the other parameters are in plain English so easy enough to work out. These things don't normally have to be changed, as you discovered in your case, but can be fine-tuned if a motor isn't behaving normally. Link to comment Share on other sites More sharing options...
JayCee32 Posted August 10, 2011 Share Posted August 10, 2011 LMSTim said:It's on pages 38 and 39 about the tipper and conveyor but when you look at the file all of the other parameters are in plain English so easy enough to work out. These things don't normally have to be changed, as you discovered in your case, but can be fine-tuned if a motor isn't behaving normally. Link to comment Share on other sites More sharing options...
JayCee32 Posted August 10, 2011 Share Posted August 10, 2011 I cannot find the Railmaster Manual which is supposed to be on the Cd provided. Have emailed Hornby Support 48 hrs ago but no reply so far. Can you offer a word of advice?Thanls in anticipation Link to comment Share on other sites More sharing options...
Hornby Customer Care Posted August 11, 2011 Share Posted August 11, 2011 Hi JayCee32,I'm sorry you haven't had a quick response to your email. You can find the RM manual in the RailMaster folder. C:\Program Files\RailMaster then the file name is Guide_en. This file is a PDF. Link to comment Share on other sites More sharing options...
LMSTim Posted August 12, 2011 Share Posted August 12, 2011 The manual is also under Start => Programs => Hornby RailMaster Link to comment Share on other sites More sharing options...
