scoones Posted October 21, 2013 Share Posted October 21, 2013 Hi All, I'm finally getting onto making my layout DCC. There are a load of points 4 of which I already had wired up to a control panel so i could 'automatically' change them. If I go to DCC whats the procedure with making all the points be changeable via a switch/DCC controller? Help please! Thanks, Scoones Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 21, 2013 Share Posted October 21, 2013 Scoones,just as locos have decoders fitted to respond to the DCC signal, point motors are connected to points and accessory decoders. The current Hornby model is the R8247. If you ok at the DCC section on this site, you'll find some information, then to learn even more, go to http://www.brian-lambert.co.uk/DCC.htm Link to comment Share on other sites More sharing options...
scoones Posted October 21, 2013 Author Share Posted October 21, 2013 Cheers dude, So I need one of these for every 4 points on the layout? and its wired up to the points via the usual point motor (R8014)? Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 21, 2013 Share Posted October 21, 2013 Yes, although where you always throw 2 points at the same time, they can be wired to the same port, so you may get 5 or 6 on the one 8247, depending on your layout needs. And if you look at my last post, whee it says ok, it should say look. Link to comment Share on other sites More sharing options...
scoones Posted October 22, 2013 Author Share Posted October 22, 2013 thats cool. ok so my (hopefully) final question, as theres quite alot that needs to be brought to update to digital, the points etc dont need to be digital right away for it to work do they? I mean a DCC train will work via, say, the Elite and if i change the points manually it wont affect the train will it. So the points can be a later addition along with the Railmaster? And the Elink? so I read on here thats if I want to control 1000 trains and more accessories - not needed in my case - right? ok more than one question there, but i think thats it :S cheers for the help Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 22, 2013 Share Posted October 22, 2013 Only thing you need to do first up is fit DCC point clips to your points so they are live in both directions all the time. Link to comment Share on other sites More sharing options...
Graskie Posted October 22, 2013 Share Posted October 22, 2013 Yes, I run a DCC layout but all my pointwork is still manually operated until such time as I operate them by accessory decoders in the distant future. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 22, 2013 Share Posted October 22, 2013 And if you have Elite, you don't need eLink. They have the same capability and you can only use one DCC controller connected to your layout anyway. With Elite, you have the possibility of continuing to operate things through it rather than using RM all the time too. Link to comment Share on other sites More sharing options...
RDS Posted October 23, 2013 Share Posted October 23, 2013 @scoones As Fishmanoz says, if you have the Elite you do not need e-link. Elite does everything that e-link does and more besides. Because Elite has control knobs and a display, it will also allow you to control your digital layout at the same time as you may be controlling it with RailMaster or with RailMaster still being connected but not actually being switched on. Link to comment Share on other sites More sharing options...
