St1ngr4y Posted October 25, 2013 Share Posted October 25, 2013 I reported a fault to RM support back in July and they haven't (so far as I know) been able to replicate it. If any RM user could spend 10 minutes on a small experimental program, I would much appreciate it. Choose any of your locos which are defined on RM and create this 2 line program for that loco:- 10 Decelerate Forward [51] to [0] 70 Stop Give the program a name and save it. The loco you chose doesn't need to be on the track for this experiment. Run the program in the main window with the chosen loco's panel on view so that you can watch the speed. After 10 seconds the speed should show 50 and then start decreasing. As soon as the speed reaches 0, make a note of the program clock time. Go back into the editor and change the times on the commands as follows: 60 Decelerate Forward [51] to [0] 120 Stop Save the changes, return to the main window and run the program again. You will have to wait, of course, for 60 seconds before the speed starts at 50, but again be ready to make a note of the program clock time when the speed reaches 0. I won't mention here what the values are that I get, so as not to influence the experiment, but if anyone can spare the time to do this and reply with the results I would be most grateful. Ray Link to comment Share on other sites More sharing options...
RDS Posted October 25, 2013 Share Posted October 25, 2013 @St1ngr4y I am surprised to see that the 1st line in your program is to decelerate. How can it decelerate without accelerating first? Link to comment Share on other sites More sharing options...
St1ngr4y Posted October 25, 2013 Author Share Posted October 25, 2013 Hi RDS, This program is simply an extract for experimental purposes, but you can have a program which for example, sets a few points and signals first then issues a Decelerate command. It is the same as having: 10 Forward to [50] 11 Forward to [49] 12 Forward to [48] etc. The first command would cause a fast acceleration to 50 using the speed curve CVs of the loco's decoder. Will you have time to help me? Ray Link to comment Share on other sites More sharing options...
RDS Posted November 19, 2013 Share Posted November 19, 2013 @St1ngr4y I must apologise for not having done this test for you before but it had slipped my mind completely. The results I get are: 1st program = 61.8 seconds 2nd program = 115.2 seconds Link to comment Share on other sites More sharing options...
St1ngr4y Posted November 19, 2013 Author Share Posted November 19, 2013 RDS said: @St1ngr4y I must apologise for not having done this test for you before but it had slipped my mind completely. The results I get are: 1st program = 61.8 seconds 2nd program = 115.2 seconds Many thanks for that. The results I got were 61 and 115. If I use start times of 20, 30, 40, and 50, the elapsed times of the decelerations are 71, 82, 93, and 104. So the further down the program is the command, the slower the deceleration rate becomes. This is really giving me a hard time producing programs. What I want to do is to produce one low-level program for each train movement, rather like you have done. Then produce high level programs with chain commands, to produce a myriad of different combinations of train movements. But if I develop a program which has, say, an accelerate command at 10 seconds, followed later by a decelerate command at, say, 40 seconds, when run in isolation this would produce a far different behaviour than if the same program were chained into another program at, say, 50 seconds, because the accelerate would now start at 60 seconds and the decelerate at 90 seconds!!! By the way, how did you record the times so accurately? As I mentioned earlier today in the Desirable Features thread, I have trouble seeing the seconds clock at the top of the main window. Ray Link to comment Share on other sites More sharing options...
RDS Posted November 19, 2013 Share Posted November 19, 2013 @St1ngr4y This is disappointing if we cannot obtain consistent results when running individual programs as opposed to chaining them from within another program because that means I would not be able to do what I was intending, which sounds very similar to your situation. I guess we have got almost identical times on these tests. I cannot claim to have recorded the times so accurately but the figures are the ones I saw, when switching my eyes from the loco speed indicator to the clock. I noticed your posting in the Desirable Features thread and although I don't have a problem with this particular display, it is a bit of a pet hate of mine, when text is printed on a coloured background. Given the choice, I would go for Black text on a white background. Link to comment Share on other sites More sharing options...
St1ngr4y Posted November 19, 2013 Author Share Posted November 19, 2013 What makes things even worse is that the rate of the acceleration/deceleration commands cannot be guaranteed to be the same when a program is run in the program editing window as it is when it is run in the main window. In fact the rate in the editing window varies depending on how deep the window is i.e. the number of program lines you have on display!!! Ray Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 20, 2013 Share Posted November 20, 2013 Can I give my standard advice and suggest one or both of you emails RM Support and refers them to this thread for details of the problems. It certainly sounds to me as if you have identified a major flaw in the software which needs their attention. Link to comment Share on other sites More sharing options...
RDS Posted November 20, 2013 Share Posted November 20, 2013 @Fishmanoz I took your advice from yesterday and I have emailed RM Support this morning, with my Chaining programs problem. Link to comment Share on other sites More sharing options...
St1ngr4y Posted November 20, 2013 Author Share Posted November 20, 2013 @Fishmanoz As I mentioned at the start of this thread, I reported the problems with the accelerate/decelerate commands back in July. The other problem of differences between the editor and main screen timings, I reported even earlier in the year. I believe they are revising the timing methods they use to be incorporated in a future release. I can't remember whether I saw that on this forum somewhere, or whether they mentioned in to me directly by email. Ray Link to comment Share on other sites More sharing options...
Rog RJ Posted November 20, 2013 Share Posted November 20, 2013 St1ngr4y said: @Fishmanoz As I mentioned at the start of this thread, I reported the problems with the accelerate/decelerate commands back in July. The other problem of differences between the editor and main screen timings, I reported even earlier in the year. I believe they are revising the timing methods they use to be incorporated in a future release. I can't remember whether I saw that on this forum somewhere, or whether they mentioned in to me directly by email. RayI'm pretty sure I read your previous post about the timing problem on this forum and the reply from the RM support stating that they would be addressing the problem. Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 20, 2013 Share Posted November 20, 2013 My apologies, just noticed the start of the thread again. One thing you have shown now is that it is not just a one-off user peculiarity but something that can be replicated by another. Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 4, 2013 Author Share Posted December 4, 2013 RDS said: @St1ngr4y This is disappointing if we cannot obtain consistent results when running individual programs as opposed to chaining them from within another program because that means I would not be able to do what I was intending, which sounds very similar to your situation. @RDS This morning I downloaded v1.54 and one of the first things I tried was the test on acceleration/deceleration. This time I added, one second before the decelerate command, set time: 23:59:59 This then acts like a stopwatch. If you have time, could you repeat the tests and if possible make a note of the stopwatch times as well. Many thanks Ray Link to comment Share on other sites More sharing options...
RDS Posted December 4, 2013 Share Posted December 4, 2013 @St1ngr4y I was just about to add to this thread that the latest version (1.54) apparently includes some changes to the accel/decel command. I will try your test out later as you have requested. Link to comment Share on other sites More sharing options...
RDS Posted December 5, 2013 Share Posted December 5, 2013 @St1ngr4y Sorry, I did not get chance to run your test yesterday. I have just done it though with the following results: Program 1) 61 seconds (Stopwatch 52 seconds) Program 2) 115 seconds (Stopwatch 55 seconds) I have not tried to read the seconds to the nearest 10th this time! (I like your idea for a stopwatch, I would like to incorporate that in my programs, some of which have repeats in them and I am always wondering how many times the program has repeated) Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 5, 2013 Author Share Posted December 5, 2013 @RDS So to summarise:- Program Version 1... 9 Set Time: 23:59:59 10 Decelerate Forward [51] to [0] 70 Stop The elapsed time of the deceleration was 52 seconds Program Version 2... 59 Set Time: 23:59:59 60 Decelerate Forward [51] to [0] 120 Stop The elapsed time of the deceleration was 55 seconds So the later in the program that the decelerate starts, the slower is the decelerate process, and 3 or 4 seconds can make a difference of a couple of feet in where the loco stops. The conclusion, however, is that the fault still exists in 1.54, despite the statements in the release notes file about improvements to the accelerate/decelerate commands and timers. Ray Link to comment Share on other sites More sharing options...
RDS Posted December 5, 2013 Share Posted December 5, 2013 @St1ngr4y Ray, your summary is correct. I can imagine that there may be some slight differences because the computer may be doing something else at the time (Goodness know what!) but 3 seconds is excessive. Having said that, the Laptop I use for running RailMaster is dedicated to my Model Railway. How do these results compare with yours? Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 5, 2013 Author Share Posted December 5, 2013 @RDS By "doing something else at the time" do you mean, for example, downloading Windows updates? If so, it would have to be doing something similar each time you do this experiment. These results are repeatable. Using the 'stopwatch', I get 1:01 and 1:05. Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 5, 2013 Author Share Posted December 5, 2013 @RDS Oops - sorry. In my version of the programs, the deceleration is from 61 to 0. Ray Link to comment Share on other sites More sharing options...
RDS Posted December 5, 2013 Share Posted December 5, 2013 @St1ngr4y 61 to 0! You have moved the goalposts. I was working on the programs you gave a few weeks ago at the top of this thread. I even have them stored in my programs list as: Prog Test for St1ngr4y & Prog Tesy2 for St1ngr4y. I have just added the stopwatch line to each of them today. When I say other things, I do not mean updates. I do those last thing ata night, with nothing else (as far as I know running) I don't know what it may be doing. My desktop hard disk light just comes on every now and again and I never know why. I must admit, I have not noticed the RailMaster laptop do it. Link to comment Share on other sites More sharing options...
St1ngr4y Posted September 14, 2014 Author Share Posted September 14, 2014 I am disappointed to find that this problem still exists in version 1.56. HRMS are you still looking into it or shall I report it again through the system?Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted October 9, 2014 Author Share Posted October 9, 2014 I have been doing some more experimentation with the accelerate command. I created the following program:-0.00 Program Command Play Sound9.00 Program Command Set Clock: 23:59:5910.00 0002 Test Loco Accelerate Forward [0] to [60]80.00 0002 Test Loco StopThe reason for the Set Clock command is so that the main RM clock at the bottom right of the main screen can be used as a sort of stop watch to do the timing. The purpose of the program is to measure the time in seconds that it takes for a loco to accelerate from 0 to 60. This is not a real loco we are talking about, it is a measurement of the way RM increases the speed of ANY loco using the accelerate command. My theory is that the RATE of acceleration applied by this RM command varies depending on the POSITION of the command within a program with respect to the start time of the program (in this first example 10 seconds).When this program is run, all you need to do is to have the loco window visible for this loco, and to keep an eye on the speed as it increases. Then as soon as it reaches 60, make a note of the time shown on the RM clock in the bottom corner of the screen.This first program behaves more or less as expected, the time taken being about 61 seconds. I then amended the program several times, each time by moving commands 2 3 & 4 forward by ten seconds i.e. highlight the Set Clock command and use the "Insert time/shift program steps" button.These are the results after 30 edits and program reruns:-Start Elapsed10 6120 6130 6240 6350 6460 6570 6580 6690 66100 66110 65120 66130 66140 65150 66160 65170 65180 66190 66200 65210 64220 63230 62240 61250 60260 60270 60280 60290 60300 60310 60As you can see, the command works fine if it is placed after 240 seconds into the program, or near the start of the program, but between 30 seconds in and 240 seconds in, the acceleration rate is slower than the expected 1 speed step per second.Ray Link to comment Share on other sites More sharing options...
RDS Posted October 9, 2014 Share Posted October 9, 2014 Hi RayFascinated to read this as I only deleted the programs I ran last year for you, earlier this week, whilst having a tidy up after defining a new program filename strategy for myself. Link to comment Share on other sites More sharing options...
idlemarvel Posted October 9, 2014 Share Posted October 9, 2014 I'll try this and get back to you with the results. Link to comment Share on other sites More sharing options...
idlemarvel Posted October 10, 2014 Share Posted October 10, 2014 My results (I didn't do all the timings)10 6120 61100 68200 66250 62So not dissimilar to your results. I also tried "100" saved as a program and run from the main window instead of in the program window, thinking that "tracing" might have an overhead, but it made no difference, still 68 seconds. Link to comment Share on other sites More sharing options...
