St1ngr4y Posted November 11, 2013 Share Posted November 11, 2013 I have been developing a program which requires a train to stop at a particular location, then reverse onto a Kadee uncoupling plate. I found it difficult to consistently get the train to stop precisely enough. OK - I hear you say when that when loco detection is released, it will help me achieve this. However, while playing around with the program, I discovered within the program editor, a program command which could be of use. It is entitled (in the dropdown list) "Pause Message". I tried to find the command in the latest PDF guide, but couldn't. I decided to try it out by inserting the pause command just after the loco stop command. Sure enough, when running the program in the main window, a message box appeared on the screen containing only a 'tick' button and a message saying press Enter to continue. I thought - great, I can now adjust the position of the train if necessary using the main RM screen controls, then press Enter and continue with the rest of the program. Unfortunately, this wasn't possible. Firstly, the message box is what is known as a Modal window, so Windows prevents access to the Main window while this box is on display, therefore preventing adjustment of the trains position. Secondly, although while this message box is being displayed, the clock at the top of the main window was stopped at the time of the pause command, when the tick button was pressed to continue the program, this clock leapt forward by as much time as the message box was on display, and the intervening commands immediately following the pause command were skipped. Before I contact RM support, has anyone tried out this command? Would anyone else find it useful if it worked properly? Ray Link to comment Share on other sites More sharing options...
RDS Posted November 13, 2013 Share Posted November 13, 2013 @St1ngr4y There is another command that can be added to programs that is just called 'Message'. It has 2 parameters that can be added: Firstly, The message you want to be displayed, which goes within the brackets and Secondly, the time you want the message to be displayed for. I have found that when the message displays on the screen that it is still possible to adjust Loco settings. The message appears in the middle of the layout screen but you can also move the layout screen around behind it. Does this help you? Link to comment Share on other sites More sharing options...
St1ngr4y Posted November 14, 2013 Author Share Posted November 14, 2013 I have tried the Message command you mention, but that's all it does - display a message for n seconds. If there other program lines within the n seconds they are obeyed without any pause. Ray Link to comment Share on other sites More sharing options...
RDS Posted November 14, 2013 Share Posted November 14, 2013 @St1ngr4y Yes, I realise that - but would it not be possible to ensure that there are no more program lines within the n seconds and make the n seconds long enough for you to adjust the position of the loco. Link to comment Share on other sites More sharing options...
