PJ_model_trains Posted December 9, 2013 Share Posted December 9, 2013 I have a question WIRING THE HORNBY POINT MOTOR TO THE DCC CONCEPTS DECODER There is power to the rails via a temporary dcc bus There are wires from the dcc bus to the DCC concepts ADS8 decoder first port. Firstly wiring in the Hornby points to the decoder... Point has 3 wires, red, black and green Decoder solenoid connections are... L, COM and R Which Hornby point motor wires go to which DCC concepts decoder connections? IS THIS... R=Red, L=Green and COM=Black? I cannot find this information on DCCconcepts website. Link to comment Share on other sites More sharing options...
Flashbang Posted December 9, 2013 Share Posted December 9, 2013 Hi Yes that is the colour code used by Hornby on their current point motors. Surface and under point types. Note there rival P**o use a different colour method. They use red and black as operation and green as the return. Link to comment Share on other sites More sharing options...
Flashbang Posted December 9, 2013 Share Posted December 9, 2013 Darn.... I meant to add, your connections on the accessory decoder are correct for a Hornby point motor. If the motor tries to throw the wrong way simply swap around the L & R connections leaving the Comm as is. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 9, 2013 Author Share Posted December 9, 2013 Flashbang said: Hi Yes that is the colour code used by Hornby on their current point motors. Surface and under point types. Note there rival P**o use a different colour method. They use red and black as operation and green as the return. Thanks for confirming the colours Flashbang. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 9, 2013 Author Share Posted December 9, 2013 Flashbang said: Darn.... I meant to add, your connections on the accessory decoder are correct for a Hornby point motor. If the motor tries to throw the wrong way simply swap around the L & R connections leaving the Comm as is. Brilliant. Thanks again. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 9, 2013 Share Posted December 9, 2013 I just gave you exactly the same answer on your other thread PJ. We must both be wrong. Not surprising no info on the DCC Concepts web site. They have info for their own stuff, not Hornby. They do assume you know that a solenoid throws left and right and needs a common, so have used terminology to match. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 9, 2013 Author Share Posted December 9, 2013 I did a search and added my message. After sending it I realised it was in the wrong section of the forum. So put a dcc message in the dcc section and a RailMaster question in that section. As we should expect, we get a faster reply (most times) if we put our messages in the relavent sections. Link to comment Share on other sites More sharing options...
RDS Posted December 10, 2013 Share Posted December 10, 2013 @PJ_model_trains Another great example of why we really need an edit and/or a delete facility on this forum. PLEASE HORNBY! Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 10, 2013 Author Share Posted December 10, 2013 RDS said: @PJ_model_trains Another great example of why we really need an edit and/or a delete facility on this forum. PLEASE HORNBY! I agree Fishy but have they got anyone to spend time on it? This is so often the problem wages are a companies biggest expense and an overhead. Having said that if a forum is not moderated, checked and kept in order it is pointless having categories to add our messages. I think the thread in GENERAL DISCUSSIONS called DCC POWERCLIP is a typical example of a run away train of messages. It started in the correct section asking this question... Hello I am wanting to disguise the dcc power clip any suggestions, regards, mike There are, as I write, 62 messages relating to DCC questions in this thread. I too am to blame, I did a search and added a message, after submitting it realised it was in the wrong section. Maybe the regular users of the forum should guide people more. If a message is in a wrong section, ask the person to re-submit it in the correct section, explain they will get a faster reply if they do. Trouble is the thread is then there in the wrong section and should be edited out. It is there for current users but lets not forget it will be there for future users when doing searches. The more messages in a search that do not answer questions for users, will result in more questions being asked on the forum! Good house keeping of the forum is essential, lets not forget it has Hornby's at the top. A name to be trusted for years gone by and hopefully years to come. With the increase in DCC loco's sales are going to increase anyway but, so are questions on this forum. Hornby are you reading this? Please! (Which section are we adding these messages to?) Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 10, 2013 Share Posted December 10, 2013 Not sure it is in the wrong section. One of the answers to the question was to hide it by soldering and not using it. Then it has turned into a general discussion on soldering technique which is not DCC specific at all. For example, WTD has added a number of posts from his DC experience with soldering to rails. Link to comment Share on other sites More sharing options...
St1ngr4y Posted July 28, 2014 Share Posted July 28, 2014 Recently I installed 5 ADS8 accessory decoders on my layout, and I am highly delighted with the outcome..... except for one little niggle which occurs now and again, and I was wondering whether anyone else has come across something similar. There is one point on the layout, connected to one of the ports on one of the five ADS8 decoders, which occasionally stops working, either through Railmaster or using the Elite controls directly. At first, I thought I might have a faulty decoder, but then I discovered that I could get it working again if I reset my Elite controller. I've had to do this maybe four times in as many months, so it isn't a huge problem. It is the only port out of the forty on the ADS8s which does this. It has an address of 29, though I fail to see how that could be significant. Maybe if I have time, I'll re-program it to a different address to see if it makes any difference!Has anyone else come across this?Ray Link to comment Share on other sites More sharing options...
Michael_A Posted August 11, 2014 Share Posted August 11, 2014 Have you tried swapping the ADS8's over (I know, lot of wires....) to see if the fault moves with the decoder? If it does, you have a faulty ADS8 and should get the shop to swap it. If the problem doesn't move with the ADS8, then try a new point motor. Link to comment Share on other sites More sharing options...
St1ngr4y Posted August 11, 2014 Share Posted August 11, 2014 But if the fault lies in either the ADS8 or the point motor, why would simply resetting the Elite and reloading RM cure the fault?Ray Link to comment Share on other sites More sharing options...
Michael_A Posted August 11, 2014 Share Posted August 11, 2014 Elimination. Something must be causing the glitch in the Elite for it to need resetting and RM to need restarting. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 11, 2014 Share Posted August 11, 2014 Do you use the recommended series resistors between the power rails and the ADS8s? If so, try adjusting the one to the decoder with the problem. If not, try installing one. Link to comment Share on other sites More sharing options...
bryan_crossan Posted August 26, 2014 Share Posted August 26, 2014 Hi Ray, I've just bought two of these and had the same problem with one of them. I had all the points working and then one double pair stopped altogether, it took some amount of changing wires to try and get it working. When I saw your email I knew something else was wrong so I changed the wires to the other decoder and it worked right away. I've had the same problem again with a different point, I reprogrammed it and it now works. The other problem I had was when I used all eight contacts the board started to get really hot but since I've moved two to three other board it's staying cool, just now but I'll have to keep an eye on it. I'm using an Ecos not the Elite.CheersBryan Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 26, 2014 Share Posted August 26, 2014 Would be worth getting on the DCC Concepts site and providing this feedback to Richard. Link to comment Share on other sites More sharing options...
bryan_crossan Posted August 28, 2014 Share Posted August 28, 2014 I've been on and they were very quick to reply. They said that the over heating could be something touching the board like a wire loose and for the loss of memory something shorting on the back. I checked all the wiring to make sure there was no loose ones and then I took two points off one and board and swapped them onto the other, reset them and everything is fine now.Bryan Link to comment Share on other sites More sharing options...
