AlanS Posted December 11, 2013 Share Posted December 11, 2013 I have just bought elink and installed it successfully. I am building an N gauge layout so Hornby loco lists not relevant. Trying to read my loco decoder CVs gives error message. Ok maybe duff decoder or I'm doing something wrong (Railmaster guide not exactly brilliant). However I thought to check voltages on output of elink box. 15V AC as expected on track output but zero on programme output, absolutely nothing there. Can this be right? Thanks for any help Link to comment Share on other sites More sharing options...
Flashbang Posted December 11, 2013 Share Posted December 11, 2013 Hi Normally only a programming track output voltage is present while programming is in operation. Check wires are correctly fitted to the programming output terminals and the programming track rails. If your using a power clip or power track section on the programming track ensure its a digital one. Ensure rail of the programming track are clean as too should the locos wheel treads be spotlessly clean. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 11, 2013 Share Posted December 11, 2013 If you are having problems reading or writing CVs and/or changing loco ID, see extensive recent coverage in RM forum, including posts from HRMS clarifying some issues. If still having problems, email RM Support from within the Help window of RM and they will solve it for you, including replacing your eLink if found to have a faulty programming track output, which has been one of the problems found with some early batch eLinks. Link to comment Share on other sites More sharing options...
Gregd99 Posted December 11, 2013 Share Posted December 11, 2013 Does RM support Operations Mode as well as Service mode programming? Only Ops mode should put volts on the programming track. Link to comment Share on other sites More sharing options...
